IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Is200 rear hub issue
Old 10-17-18, 01:11 AM
balboa11
balboa11's Avatar
Default Is200 rear hub issue
Hi. i needed replacement rear bearings and the brake backing plates. I got 2nd hand hubs with backing plates and all fitted. Replaced the bearings on the 2 replacement hubs and re-attached everything. However, when i tighten the hub nut onto the driveshaft, the more i tighten the nut, the more the hub grinds to where it wont actually spin at all. Its as if the abs ring is grinding on the inside edge. Does anyone have an idea what could be the problem?
Bocatrip
01-28-19 02:00 PM
Lzam
05-07-17 10:19 PM
fueler
05-11-16 09:48 AM
np20412
Suspension and Brakes
06-11-07 06:03 PM
Quick Reply: Is200 rear hub issue
