confused with new codes please help
hello again. thank the forum for the help i have received!
2006 IS250 130k
i had the car check engine light looked at (ive had the CEL on for a few months working on a costly and complicated EVAP problem,kind of a draw back of the system that if something else goes wrong you'll be none the wiser). and came back with PO 335,340,345,365,390 which correspond to camshaft position sensor A bank 1 and 2 and B bank 1 and 2.
while doing some maintenance recently, my girlfriend cleaned under the hood with cleaner getting rid of dirt and such. just seems like too much of a coincidence that BOTH banks of both sensors are coming up?
no problems starting, idle is smooth but i would have to say its very sluggish, specially at lower speeds and has been that way. i know if the purge flow is stuck open that it may cause some problems so until now i just assumed it was related to the EVAP problem.
thanks guys
2006 IS250 130k
thanks guys
Rawb1584
RX - 1st Gen (1999-2003)
09-13-21 09:28 PM
Austinian
05-06-15 06:11 PM
