IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Maintenance feedback needed TIA
Old Dec 6, 2015 | 02:14 PM
Esfour's Avatar
Esfour
Default Maintenance feedback needed TIA
Hey guys I recently purchased a 2002 Crystal White SportCross Wagon. It has 217K and I am looking at it as though no maintenance was done so I am looking to refresh everything needed.
Below is the information I have gathered and would love to get feedback on what I'm missing as I want to knock everything out before I put it on the road.
Suspension:
Ball Joints-Front Lower (MOOG)
Control Arms-Front Lower (MOOG)
Stabilizer Bar Bushing- Rear to Frame (MOOG)
Stabilizer Bar Link- Front & Rear (MOOG)
Steering:
Tie Rod End- Right & Left Outer (MOOG)
Tie Rod End- Inner (x2?) (MOOG)
Engine:
Motor Mount-Front Left & Right Hydraulic (DEA)
Oil Pan Gasket (Victor Reinz)
Timing Belt Kit:
Timing Belt (Toyota)
Idler #1 (Toyota)
Water Pump w/seals and o-rings (Toyota)
Hydraulic Tensioner (Toyota)
Front Cam Seals (Toyota)
Front Crank Seal (Toyota)
Thermostat (Toyota)
Thermostat Gasket (Toyota)
Valve Cover Gaskets (Toyota)
PCV Valve (Toyota)
Oil Filter (Toyota)
Drain Plug Gasket (Toyota)
Drive Belt (Toyota)
Fluid Change (Drain & Fill):
Coolant
Transmission
Brake
Anything else I'm missing?
If there is anything else I should look at suspension, engine, transmission, etc wise, please do let me know as I am trying to get everything done once.
Few other things I'm looking for is:
*Rotors/pads combo should I look at? Not looking to do any BBK
*Coilovers wise what to go with? I don't need the best of the best, this will be a daily driver and sprint driving from time to time. After researching I read CXracing was a good one to go with over Megan. Any feedback?
Thanks,
Old Dec 8, 2015 | 04:58 PM
1997Soarer's Avatar
1997Soarer
Spark plugs
Y-pipe intake manifold gasket
Throttlebody gasket
Transmission mount
Old Dec 9, 2015 | 08:54 AM
Esfour's Avatar
Esfour
Brian,
Thank you for responding. Typically what plugs do you guys run? I bought the transmission mount since I figured I was doing the engine mounts it only made sense. I'll have buy those gaskets from Toyota or Lexus dealership locally.
Thanks
Old Dec 25, 2015 | 09:55 PM
pharmer2jz's Avatar
pharmer2jz
Don't forget air filters, engine and cabin.
dveneman
21
Jan 27, 2021 09:23 AM
Desacatao
Mar 12, 2019 07:28 PM
isam250
General Classifieds
Dec 18, 2014 07:42 PM
Gennady7
Mar 27, 2009 05:59 AM
