IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
engine falls on its face @ 4k RPM
Old Jul 11, 2013 | 05:30 PM
khay425's Avatar
khay425
Angry engine falls on its face @ 4k RPM
My 02 IS300 MT starts shuddering at 4k RPM in any gear or weather condition. No check Engine light. I have a aftermarket intake but everything else is stock. Has anyone else had this problem??
Old Jul 15, 2013 | 06:42 PM
Willmkent's Avatar
Willmkent
give a little better description. what exactly do you mean by shuddering. what are your RPMs doing at this time?
have you done all of your basic and regular maintenance?
Old Jul 19, 2013 | 09:44 AM
khay425's Avatar
khay425
car drives fine in each gear until you hit 4k RPM. Then the engine has very little power. Rpms stay the same. If you keep your foot in the throttle the RPMs will go up but very slowly. Possible lack of fuel/air?? Feels like it is has a misfire.
Just bought it in January. Had everything replaced...spark plugs, T-Belt, all seals and fluids.
since i posted the original comment my check engine light has come on. Pulled the code and it looks like i need a cat. not sure if it could be related.
Not sure where to start>>>>>>>>>>>>>>>>>>>>>>>>
Old Jul 19, 2013 | 05:54 PM
ToyotaPro's Avatar
ToyotaPro
cats are bad for coming apart and lodging themselves in the exhaust. This could also be caused by a mass air flow issue and with the car going lean constantly could cause the converter failure also. I would check the MAF sensor and then the Cats after that.
Old Jul 21, 2013 | 11:39 AM
khay425's Avatar
khay425
Will do..... gracias
Old Jul 23, 2013 | 04:00 PM
Tvo1293's Avatar
Tvo1293
Could u fix all this with an o2 pnp, headers and an exhaust?
chenxingha
RX - 1st Gen (1999-2003)
Apr 21, 2018 11:04 AM
helms
Aug 31, 2015 01:25 PM
davids75
Jan 6, 2013 08:16 PM
gsta127
Apr 20, 2010 02:10 AM
maniax
Oct 9, 2006 04:49 PM
