IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Changing HID Bulbs
Old Dec 15, 2012 | 05:58 PM
01BabyLexy's Avatar
01BabyLexy
Default Changing HID Bulbs
Hello all,
New member here. I did a search and found tons of articles for changing out the HID bulbs. I made a mistake when changing out the driver's side HID bulb. Instead of twisting the grey cable and then unclip the harness, I unclip the hardness first and pulled the bulb straight out of the socket. Now the problem is that the bulb is attached so hard to the grey cable that I'm having a tough time getting it out of the socket. Any tips on this? I have countless cuts on my hands trying to twist the bulb out of the socket, but to no avail. Thanks.
Old Dec 16, 2012 | 02:50 AM
SuthrnGent's Avatar
SuthrnGent
Try putting the bulb back into the socket, reclip the wire, and twist the grey cable off from the bulb. It can be tough to work in that small of a space, but it can be done. Good luck
Old Dec 16, 2012 | 10:26 AM
01BabyLexy's Avatar
01BabyLexy
Just an update on this. I'm still working on taking the grey cable off but it's such an ***. Grrrrrr!!!
Old Dec 16, 2012 | 06:33 PM
hernadoric's Avatar
hernadoric
Old Dec 24, 2012 | 01:34 PM
01BabyLexy's Avatar
01BabyLexy
Just a update on this. I was able to remove the bulb with two pliers because it was stuck so hard on the grey cable. Note to self: remove cable before unclipping the metal wires. Thanks all.
DJSTYLE
Jul 22, 2012 01:18 PM
jewel
Jul 29, 2009 09:10 AM
superpats
12
Feb 2, 2006 12:46 PM
rominl
Lighting
Mar 21, 2003 04:50 PM
retrodrive
Lighting
Mar 6, 2003 10:10 AM
