breakin in my engine...
how long do you guys think i should wait till i start racin or goin fast? i have about 970 miles on it at the moment...should i wait till 1000 miles or more then that? thankz
There are several break--in procedural roads to take, and several really notable engineers with books written on the subject. The only thing they agree on is that long-term constant-RPM during break-in is disadvantageous. They know this based on bench-test data that says motors operated at low-load, fairly constant RPM are significantly worse off after a large number of miles have accumulated on the engine due to the ring-to-bore match (created during this type of break-in) that is violated over time. Result? oil leaks, reduced compression, etc.
In your case, break-in is over. Drive the car.
For your next car, this convention will once again have been visited by numerous mechanical engineering graduate students that will still have nothing conclusive.
Your Lexus is over-designed. Drive it.
akaido
NX - 1st Gen (2015-2021)
May 14, 2016 12:46 PM
