IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Driver's door lock not functioning
Old Mar 31, 2010 | 08:34 PM
Proudvegan's Avatar
Proudvegan
Cool Driver's door lock not functioning
FYI: I posted this in Maintenance thread, but didn't know about this section, sorry...
2005 IS 300.
My driver side door will not lock or unlock with my key and it has to be done manually. (all the other doors are fine). I have read that it is not common among LX owners but it was never mentioned for this particular model.
I am trying to find out if its the fuse or the relay in the door panel that might be the problem.
First I want to check to see if its the fuse before I check with opening the door panel and checking to see if its the solenoid/relay.
I checked my manual and the door look fuse is in the driver side kick panel but how do I open it? Its not visible to me....
I appreciate your reply!
Old Mar 31, 2010 | 08:42 PM
MVPTonyD's Avatar
MVPTonyD
what do you mean by manually? can you not lock it by pressing the lock on the door? if so, do this
https://www.clublexus.com/forums/gs-...ators-diy.html
its for a gs400 but same stuff really.
Old Oct 14, 2010 | 07:48 AM
ISFFUN's Avatar
ISFFUN
My 2005 started doing this too. I'm hoping the dealer will cover it under warranty but I doubt they will.
Old Oct 14, 2010 | 08:48 AM
03LexIS300's Avatar
03LexIS300
sounds like your door lock actuator has gone bad or the cable in there is stretched/unhooked/or broke in two, it isn't a rod like most cars. the IS300 has an insulated steel braided cable that works the door lock and the insdide door handle. this happened to my passenger side door in my 04 IS300 when I had it a year ago. mine wouldn't unlock with the remote or with the lock/unlock button on the driver's or pass side doors.
Old Oct 14, 2010 | 06:53 PM
chunktwo's Avatar
chunktwo
http://my.is/forums/f103/diy-guide-d...-motor-414788/
it was just the motor in the door lock module..
was a $10 fix and about an hour of my time.
Old Oct 19, 2010 | 04:51 PM
Thomboy68's Avatar
Thomboy68
My 2005 Highlander seems to have a similar problem as the remote will not open the driver's door, but still opens all the other doors. I wonder if the motor in the door lock module is similar for the Highlander as your 04 IS300? I used the link mentioned by chunktwo and I think it says Toyota/Lexus motor for door lock actuator? Anybody else ever do this for a Toyota car, like my Highlander?
elwhite68
NX - 1st Gen (2015-2021)
Feb 26, 2018 12:56 PM
SonicISF
IS F (2008-2014)
Mar 19, 2017 09:12 AM
tigerm25
RX - 1st Gen (1999-2003)
12
Oct 2, 2013 09:21 PM
jbgunn
Aug 29, 2011 09:43 PM
Proudvegan
Maintenance
Apr 1, 2010 03:26 PM
