IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Engine Part....
Old Jul 26, 2009 | 06:35 PM
hobojoe's Avatar
hobojoe
Default Engine Part....
Hey guys in the middle of an srt Install and happened to break the "No. 3 camshaft bearing cap" but i can't find that damn part listed on any sites only the nuts and bolts for it any ideas?
Attached is a pic of what it is.... circled in red Thanks!
Old Jul 26, 2009 | 07:14 PM
3rdelement's Avatar
3rdelement
to clear any confusion, he is doing an install on an is300.
Old Jul 26, 2009 | 07:26 PM
hobojoe's Avatar
hobojoe
^^^ Ya good point not my LS
Old Jul 27, 2009 | 09:54 AM
RCPnoi's Avatar
RCPnoi
try shooting a message with that information to justisparts on ebay.
i did that when i accidentally broke my vvt sensor
Old Jul 27, 2009 | 02:30 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
Dude - you are screwed. The caps are not available as individual pieces because they're line bored in the head when the head is machined from cast. It might be possible to get incredibly lucky and find one at a junkyard that will still allow the cam to turn, but it's unlikely. Usually you need a whole new head (or a junkyard head) with caps machined to work on that head.
Old Jul 27, 2009 | 04:37 PM
hobojoe's Avatar
hobojoe
^^ Its what ive read considering trying to use the piece since its 95% intact and the 2 main Allen screws holding it down are both ok ...... maybe tig, or jb weld the other 2 back in just for extra security.....
Old Jul 30, 2009 | 09:33 PM
lobuxracer's Avatar
lobuxracer
Tech Resource
If you TIG it, you'll warp it to hopelessness. JB might hold depending on the springs you're using, but will fail over time. That particular cap also has a seal in it if I remember correctly so even repairing it, you'll likely have a leak from the seal (unless you goop it up with a lot of monkey snot.) Yeah, there are some kludges you can do, but none of them will last any serious length of time and you'll be back with the head off and replacing it before you know it. And you'll be doubly pissed off.
PseudoK
Oct 14, 2023 10:41 AM
Stilkus
Dec 2, 2018 01:00 AM
BrownGuy
Dec 31, 2010 03:43 PM
SC300T
Nov 11, 2002 09:47 PM
