Help asked!
This morning i started my is and the check engine light stay on!
whats the most common problems with the is 300 when the check engine light is on?? Sorry for my bad english but please help me! I'm very nervous i hope there nothing major! Thanks a lot!| lexsyl20 2001 is 300 73 096 |
the common problem is the oxigen sensors, that happen with mine ,maybe thats will be your problem, check wiht the scanner to be shure
most common may be the oxygen sensors, or the fuel cap left open. Try disconnecting your battery for 10 mins then put it back on. If the ses light comes back go to an autoparts store to get your codes read and post the codes
Originally Posted by MurdaM
(Post 4184977)
pull out the ecu fuse along with another one. can't remember off the top of my head |
Get the code read with an obdII scanner or whatever it's called. That will tell you what is wrong.
On my '02 it was an oxygen sensor..
My CEL is still on after 6 months. No problems, but found out it was my o2(oh-2) sensor. So I figured its not a big issue, but your MPG goes down a little.
If its the pre catalytic converter sensors, you dont have to worry about the light. If its the post catalytic converter sensors, you CEL would be on and your TRAC OFF will be flashing. That means either your o2 sensor or catalytic converter is bad. Our cars have 4 o2 sensors. Look under the hood and below the intake pipe, you will see your headers. On the headers, you will see a gadget with wires. That is an o2 sensor. Then further down the exhaust, you will see a big canister. That is your catalytic converter. To find out what the problem is, just go to a near by auto parts store and ask them to read your car. Its an OBD-II(OBD-2) ECU reader. Then have them right/type/print the codes. Then come back and post them up. We can direct you in the right direction. And its free help, so you can use the money to buy the $150+ part you will need :sad: EDIT: I almost forgot :egads: To reset your ECU, just unplug the negative(black) cable from the battery for 15 mins. Then plug it back in. Start the car, BAM!!! your CEL light is gone. Wait about 5 mins or so. If the light doesnt come back on, then it was a warning. But dont let that fool you, it will come back on eventually. |
Hey Guys !
The code was p0172 Did someone know something about this code? |
this is wat i found P0172
System Too Rich (Fuel Trim) |
* The MAF (Mass Air Flow) Sensor is dirty or faulty. Note: The use of "oiled" air filters
can cause the MAF to become dirty if the filter is over-oiled. There is also an issue with some vehicles where the MAF sensors leak the silicone potting material used to protect the circuitry. * There could be a vacuum leak . * There could be a fuel pressure or delivery problem Or a possible probelm with an oxygen sensor are my guesses here |
Thanks!!!!!!!
Originally Posted by I<3myIS300
(Post 4196911)
I have a 2006 es330 and the trac off light came on today and I only have 39k miles on my car what could be the problem?
Wrong section. You want the ES330 section for this answer...
Here: https://www.clublexus.com/forums/es3...330-forum-179/ |
