245/45/17 up front what offset is needed?
For SCCA Solo II I would like to run 245/45ZR17 on all four corners what offset will be needed? so that I do not rub?
What is the stock offset, 45mm?
The wheels have to be 17x7"
How far out will 245 stick?
CAll wheel source ask for dave he set me up with a set of 265 30 18 in the back and 235 or 230 35 18 in the fron and has the offset perfect no rubbin and no rolling of my fenders... his number (937)299-0035 tell him Ryan sent ya...
You're in for a surprise if you want to put tires that wide & that tall on an IS... a 245/45-17 is just (barely) more than 1" taller than the stock 215/45-17, and is way too wide for the narrow 17x7 +50 wheels (most tire manufacturers specify a minimum wheel width of 7.5" for this tire, an 8.0" to 8.5" is closer to optimal).
I don't think there is any possiblility of these not rubbing, especially in the front, regardless of offset. Not to mention how different your gear ratios will be with such a tall tire...
