IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Need some help!
Old May 23, 2007 | 06:35 PM
infra917's Avatar
infra917
Default Need some help!
My car is having idleing problems. When i'm stop the car seems to drop below 1000 then violent shake to return in back above the norm. it drives fine, just having problems sitting there. any ideas?
Old May 23, 2007 | 06:47 PM
Carbon~IS's Avatar
Carbon~IS
I would check vacuum lines for leak/crack/loose.
Also check the MAF, and clean it if needed.
Old May 23, 2007 | 07:00 PM
Wazmo300's Avatar
Wazmo300
Vaccuum sounds like to me also, pin holes in lines will do that...
Old May 27, 2007 | 11:45 PM
infra917's Avatar
infra917
bad ignition wiring.
Old May 28, 2007 | 05:27 AM
Carbon~IS's Avatar
Carbon~IS
Coil Pack?? You didn't get a CEL??? Or you did, and that's how you found out....
Either way, coil packs are kinda pricey... Good luck, and hope you get her running right soon
Scjunky94
Dec 4, 2015 08:51 AM
halfrican6
Feb 1, 2013 10:49 AM
supraclay
May 2, 2012 09:03 AM
toy4life86
Apr 18, 2012 11:36 AM
varcity64
Jul 7, 2006 09:25 AM
