IS - 1st Gen (2001-2005) Discussion about the IS models up to the 2005 model
Evap Codes Troubles
Old Apr 13, 2025 | 07:18 PM
userr's Avatar
userr
1st Gear
Default Evap Codes Troubles
Got a 02, 300k on dash, stock motor, was rebuilt @215k
got p0420/430/440/446
no other codes car runs like a champ, but i currently can’t pass smog.
so far i replaced a good amount of vaccum lines, VSV switch, exhaust gaskets.
While at cold start or acceleration i smell exhaust smell in the cab.
i’m thinking that it’s the rollover valve or charcoal canister. My cats seem good no smoke or rotten egg smell. Just need some advice and help.
Old Apr 14, 2025 | 03:38 AM
2001SolarY's Avatar
2001SolarY
Active Streak: 30 Days
Cats do not need to smell or smoke to be bad. Replace them. As for the other codes. Smoke testing is the easiest way to find it.
Old Apr 14, 2025 | 07:16 PM
TobiasSing's Avatar
TobiasSing
Yep, those first two codes mean you need new cats.
Old Aug 20, 2025 | 02:58 PM
DanielleAlek's Avatar
DanielleAlek
To get that EVAP code taken care of, if you've already been replacing the usual suspects, you might need a smoke test kit. The Ancel S300 and S3000 are pretty decent for a reasonable price, you'll save money over time buying one of those for a couple hundred bucks instead of parts-swapping until the issue goes away.
But, what other people aren't noting is that you're telling us you smell exhaust, not gasoline, in the cabin. Checking to see if your EVAP or EGR valves are stuck open is a good first step, but also, check for an exhaust leak, particularly before the O2 sensor. An exhaust leak in the manifold itself can throw those codes. Checking your fuel trims might be another good place to look - Is it running lean? Rich? Normally? While you're already checking your fuel trims, it's a good idea to check your O2 sensors and what information they're feeding the computer. If you don't already have a scantool, I actually have a basic $30 one that I take with me everywhere that can look at live data - AutoLink AL319 .
A lot of the time, you can find exhaust leaks by using a spray bottle with soapy water in it and spraying it on suspected leaky areas - The mating of the manifold and the head, the O2 sensor holes, places like that.
These sorts of issues actually can trigger P0420 even if your cats are good. Get that leak taken care of, then address the cats. Once you've taken care of that leak, you'll be able to better interpret live data coming from your O2 sensors and figuring out if your cats are actually bad or not.
Happy hunting!
prossi1
Jun 16, 2019 03:59 PM
shadykev
Jun 16, 2016 09:31 PM
20012003rx
Jun 13, 2015 10:22 AM
peafarmer
May 15, 2015 08:16 AM
thaeleelyr
RX - 1st Gen (1999-2003)
Jan 16, 2013 05:21 PM
