Hybrid Technology Unique topics related to the 2023 up RX model hybrid drivetrain and other features/options found only on the hybrid models. Please use the main forum for discussion about shared components with other fifth generation RX models.
Octane for RX350h?
Old Feb 21, 2023 | 12:38 PM
Eagleboy99's Avatar
Eagleboy99
The reason there are dozens of computers in your Lexus is to manage things like octane. Adding higher octane fuel only reduces your bank balance.
Old Feb 22, 2023 | 11:17 AM
jahnjva's Avatar
jahnjva
Default octane/fuel/top tier
Since the 350h can use either 87 or higher fuel, I think it's more important to use a top tier gasoline (costco is prob the least expensive one) see link below.
https://www.autolist.com/guides/top-tier-gas
Old Feb 22, 2023 | 02:34 PM
Eagleboy99's Avatar
Eagleboy99
The Shell Canada Lawsuit was a class action suit filed against Shell Canada Limited on July 18, 2003, on behalf of customers who purchased "Bronze" (regular-grade) gasoline products, to which Shell Canada added an "additive", between March 1, 2001 and April 15, 2002. This additive allegedly caused damage to the fuel supply system of many cars, most commonly of Acura, Chrysler, Dodge, Ford, General Motors, Hyundai and Volvo brands. While Shell Canada estimated that between 100,000 and 200,000 customers bought "Bronze" products during that period, it is unknown how many total vehicles were affected. Top tier gas.
Old Feb 28, 2023 | 03:14 PM
Pitch1's Avatar
Pitch1
1st Gear
Originally Posted by Gwizzy
Hey guys. I originally ordered the NX350h but someone canceled an order for a RX350, so I jumped the gun and got that instead. I'm seeing a ton of debates regarding which fuel type to use. I understand that the 2023 rx350 now has a new turbo charged engine, so does that change the fuel required? I'm from Toronto and regular gas here is 87. I read on a dealers website that the 2022 rx350 can use a minimum of 87. Anyone know if that's the case for the 2023 rx350 as well? I'd rather not spend the extra money on more expensive fuel if I don't have to. Thanks in advance!
I'm still on my first tank of fuel (regular) provided by the dealer for our new RX350h, my next tank I'm going with premium to see if there is less engine noise or any noticeable performance difference and will revisit this post once I have a change to drive with the premium fuel.
Old Mar 3, 2023 | 05:01 AM
Freds430's Avatar
Freds430
I have used 87 octane in our 2015 RX450h and currently 2017 which both premium is required. Experimenting with the other two levels, I have noticed zero difference in gas mileage or performance. I have used 87 in cars that have required premium for over a million miles and have not had one problem.
I always revert back to two MIT graduates that are car mechanics who had a syndicated radio show called Car Talk for 35 years.
http://www.cartalk.com/content/premi...egular-0#myth4
From the USA Today:
The only modern engines that should really need premium are those with superchargers, which force-feed fuel into the cylinders. "You're driving along and just tramp the gas and the knock sensor cannot sense the knock fast enough in some cases," because the supercharger boosts pressure so fast, says Bob Furey, chemist and fuels specialist at General Motors.
Burning regular when the owner's manual specifies premium won't void the warranty, nor damage the engine, even the most finicky automakers say. "You're giving up perhaps just a little bit of performance that a customer wouldn't really even notice, it's so slight," says Furey._______________
We all love our Lexus's. I call it the placebo effect. If it makes you feel better putting 91 octane in your vehicle than go for it. There is no wrong decision just a difference in $$$$$. Someone posted a couple years ago a response about octane levels that 91 octane he swore made his transmission shift smoother.
Old Mar 3, 2023 | 07:06 PM
Elvisfan's Avatar
Elvisfan
Even the CR video that you posted says that if your car requires premium, you should use premium.
Old Mar 4, 2023 | 04:23 AM
Freds430's Avatar
Freds430
Saw that and still don't and never had and never will. It makes no difference in mpg or acceleration. As stated driven over one million miles on regular in vehicles that require premium with of course zero engine problems. The only problem is what to do with my extra $$$$. By all means if it makes you feel better use premium.
Old Mar 4, 2023 | 09:48 AM
Eagleboy99's Avatar
Eagleboy99
Pretty much every car warranty has a line like "The warranty will not cover any failures arising due to misuse or abuse and handling against the instructions of the owner's manual." So if there is detonation damage you could be held liable.
Old Mar 4, 2023 | 12:58 PM
Elvisfan's Avatar
Elvisfan
I’ll continue to follow the owner’s manual on my car.
Old Mar 11, 2023 | 12:35 PM
ggebhardt's Avatar
ggebhardt
My dealer told me that 87 octane will not cause any harm in my 23 350h. You might lose a couple of hp but not enough where you would feel any difference in performance. Both of my local dealers fill your tank up with 87 octane from the on-site tanks. Todays computer controlled engines will adjust and run just fine.
Old Mar 12, 2023 | 02:06 PM
Elvisfan's Avatar
Elvisfan
Originally Posted by ggebhardt
My dealer told me that 87 octane will not cause any harm in my 23 350h. You lose a. Couple of hp but not enough where you would feel any difference in performance. Both of my local dealers fill your tank up with 87 octane from the on-site tanks. Todays computer controlled engines will adjust and run just fine.
The hybrid does not have a turbo. Premium is only recommended, not required.
Old Mar 12, 2023 | 03:21 PM
ggebhardt's Avatar
ggebhardt
Originally Posted by daryll40
Yes. Which means the MPGs on the sticker (of the turbocharged, non-hybrid RX350) really have to be reduced by 3-4 MPG to equate to “regular vehicles” that run on 15-20% cheaper regular gas.
‘Won’t be 3-4 mpg, it will be more like 1-2 mpg.
Old Mar 12, 2023 | 05:01 PM
oommeng's Avatar
oommeng
6th Gear
Default Gas mileage
Originally Posted by blown5.0
Hi,
I was wondering what octane rating folks with the hybrid RX350h were using? For those using 87, is there a noticeable mpg or performance hit?
Since I started using 89 I have seen a marginal increase in mpg. The best I have so far is 34.2 mpg. The car has done 1300 miles so far and the gas mileage has been steadily increasing. I will continue using 89 since it would be better for the engine.
Old May 2, 2023 | 07:45 AM
YWW's Avatar
YWW
Question Regular gas on 2023 RX hybrids?
So yeah, the Premium is the sweet spot for price and options. And it’s a 4000+ lb vehicle getting 36MPG on regular gas. I wouldn’t worry about “NVH”. You’ll love this vehicle if you’re a Lexus person.
Just curious why you are using REGULAR gas on your 2023 RX? I understand all 2023 RXs hybrid and non-hybrid all require premium gas whereas on the 4th generation RXs regular gas can be used on non-hybrids.
Old May 2, 2023 | 07:50 AM
Eagleboy99's Avatar
Eagleboy99
The 350h DOES NOT require premium gas.
