Hybrid Technology Unique topics related to the 2010 - 2015 RX450H model hybrid drivetrain and other features/options found only on the RX450H. Please use the main forum for discussion about shared components with other third generation RX models.
2010 rx 450h P0A7A error
Old Sep 3, 2021 | 12:21 PM
Paul2010's Avatar
Paul2010
Default 2010 rx 450h P0A7A error
I keep getting this error on my RX450H. The car won't start. Dealer said it was the inverter and it would be $8k for a new one. I replaced the inverter myself with a refurbished model. I pulled the hybrid battery, checked it and reinstalled it but still get the error. It will go to ready then make a clunk sound and then nothing. Not sure if its an ECU issue or what. I don't want to throw parts at it chasing this down. Its very frustrating. Any help would be greatly appreciated.
Old Sep 3, 2021 | 02:01 PM
Clutchless's Avatar
Clutchless
If and when you give up you may want to consult with this independent hybrid specialist shop if you want to avoid the dealer. They have many locations around the US.
​​​​​​https://www.thehybridshop.com/
Old Oct 12, 2021 | 12:55 PM
Mbison83's Avatar
Mbison83
Any luck with this?
Old Oct 13, 2021 | 05:23 PM
salimshah's Avatar
salimshah
25 Year Member
Error codes never identify a problem. One can blindly replace and if lucky the problem is solved. But the error code should be followed by measurement. There is lethal voltages involved so a safer way would be to go to a tech,
can be used to educate.
Then voltages should be measured at the input of the converter. If energized the drive motor would spin ... so drive motor needs to be disconnected.
Salim
momogala
Hybrid Technology
Sep 20, 2021 12:00 PM
CarloRX
Hybrid Technology
14
Jan 28, 2013 06:53 PM
BobThorton
RX - 3rd Gen (2010-2015)
15
Jun 15, 2012 08:40 AM
dvnola
17
Aug 28, 2010 08:27 PM
4482
Apr 8, 2009 04:45 PM
