Hybrid Technology Unique topics related to the 2004 -2009 RX400H model hybrid drivetrain and other features/options found only on the RX400H. Please use the main forum for discussion about shared components with other second generation RX models.
2008 RX400H Class Action/ABS Assembly/Live Stream
Old Sep 9, 2020 | 08:43 AM
deanmitch's Avatar
deanmitch
Default 2008 RX400H Class Action/ABS Assembly/Live Stream
Hey folks. Lexus will not honor a warranty extension on my wife's 2008 400h, even though they never informed us of the ABS brake assembly warranty extension back in 2016, and we've been the vehicle owners since 2014. Warranty extension was mailed to previous owner and covered through Nov. 2018, so we're SOL. Regardless, moving forward, here are my questions:
1. I have red warning light, red brake light, and amber lights on ABS, traction control and the exclamation point in parenthesis). Will Tech Stream be able to pinpoint the problem? I have an OBD II scanner, but this does nothing, as there's no check engine light. I want to be 100 percent certain it's the ABS Brake Assembly prior to spending $550 on EBay for a used one.
2. Is anyone aware of a class action suit or pending recall for this problem? Seems very common on Lexus SUV hybrids 06-08 and same for Toyota Highlander in same years. Naturally, as it's brake-related, it seems serious enough to warrant a recall.
3. Has anyone here replaced the ABS brake assembly on their RX 400h or Highlander hybrid? If so, could you provide pics/details/video? Will also have to know how to bleed. (Please don't tell me to simply take it to mechanic. I can handle this, but would appreciate guidance).
4. Is there a way to confirm the ABS Brake Assembly/Actuator are bad with a multimeter/ohm meter?
Thanks in advance for any help you can provide. FWIW, I had the 12V battery tested at AutoZone, and they said it was fine. The codes still exist, even after pulling the 12V battery. Along with the array of lights, I have "Warning: Check Vehicle Stability Control." "Warning: Check System," and "Warning: Check Hybrid System." According to the service manager at Lexus dealership, based on the ABS and Brake light warnings and red "warning light" with exclamation point (accompanied by high-pitched buzzing and hard to depress brakes), he's 99.9 percent confident the ABS Brake Assembly needs replacing.
Old Sep 10, 2020 | 10:21 PM
iMSQ's Avatar
iMSQ
https://www.clublexus.com/forums/hyb...l#post10388337
Old Sep 12, 2020 | 05:53 PM
ukrkoz's Avatar
ukrkoz
Yes, you can replace it yourself.
To bleed system, you either need to use Techstream or, place system into service mode and bleed conventional way.
There are severla posts about this in HiHy sections at toyotanation.
Old Sep 12, 2020 | 06:03 PM
ukrkoz's Avatar
ukrkoz
https://www.toyotanation.com/search/...uator&t=post&c[child_nodes]=1&c[nodes][0]=221&o=relevance
https://www.toyotanation.com/search/...odule&t=post&c[child_nodes]=1&c[nodes][0]=221&o=relevance
https://www.toyotanation.com/threads...#post-14260295
Post #4 has link to bleeding PDF
One is with Techstream and one is without
TSkyy
RX - 3rd Gen (2010-2015)
Aug 13, 2018 11:40 AM
Chiguylay
Aug 30, 2016 01:55 PM
uMulla
Sep 10, 2012 05:03 AM
Azbrigada
May 8, 2012 07:41 PM
