Es 300h hybrid making funny noises after turned off
Old Dec 3, 2019 | 09:30 AM
12jimmyjam's Avatar
12jimmyjam
Default Es 300h hybrid making funny noises after turned off
Hey all. Although is usual for the hybrid to make some noises after shutting off, I’m getting a weird one on my 2013. Intermittently I’ll hear what sounds like a chair dragging across the ground for a brief second. When inside the car, I can feel vibrations from behind the pedal area. I’m sure it’s part of a regular shutdown sequence but it sounds like maybe something might need some lube. Tried to catch it on audio but it’s somewhat random and occurs up to a couple of minutes after. Car has just under 90k miles. Thanks!
Old Dec 3, 2019 | 02:25 PM
jollick's Avatar
jollick
Not sure it the same as yours but I hear and have always heard at times after turning off my 2013 a sound that no other car I have had makes. Almost sounds like a rubber door closing that needs oiling.
Old Jan 10, 2020 | 06:31 PM
12jimmyjam's Avatar
12jimmyjam
Just read about other Toyota/lexus hybrids having problems with brake actuators and/or needing the brakes bled that make a sound like a seal barking. Does anyone know where the brake actuator is located at on the es hybrid? I’m hearing the noise from under the driver’s pedals.
https://www.clublexus.com/forums/hyb...l#post10703878
Old Jan 11, 2020 | 10:25 AM
jollick's Avatar
jollick
I do not think that link is related if you look at the 1st post. I also believe the sound is normal. I have had a 2010 HS250h and now the 2013 ES300h. Both have made this sound after parking the vehicle.
wmogolov
ES - 7th Gen (2019-2025)
50
Nov 13, 2018 08:54 AM
billm555
Oct 21, 2018 07:55 AM
umpalumpa
CT 200h Model (2011-2017)
Sep 12, 2012 08:49 AM
Infin1ty
May 16, 2008 03:00 PM
lexusman1
Jun 17, 2006 09:56 AM
