Hybrid Technology Unique topics related to the 2010 - 2015 RX450H model hybrid drivetrain and other features/options found only on the RX450H. Please use the main forum for discussion about shared components with other third generation RX models.
80k miles - maintenance needed - thoughts?
Old Jan 2, 2019 | 07:42 AM
desmo907's Avatar
desmo907
Default 80k miles - maintenance needed - thoughts?
2013 450h approaching 80k miles and running great. (Bought new in 2013.)
I usually take to dealer for routine maintenance but that consists of oil change and rotating tires. I can change filters, wipers, etc. myself.
But is there anything else I should maybe have the dealer examine/do at this mileage?
(Still have original brakes and battery.)
(Book notes some things to torque, etc. but does brake fluid really need to be changed, etc.)?
Thx in advance!
PS. I love the vehicle. Never use on-board computer for mileage (it is not accurate) but do my own calculations and run ~28-30 mpg in summer (mix of fast highway and city in ECO mode) and ~4 mpg less in winter. Car could use some improvements especially the driver seat (for 190lb man).
Old Jan 2, 2019 | 09:25 AM
salimshah's Avatar
salimshah
25 Year Member
Do the items that the book says, including brake fluid.
Rest is all optional.
There are /suspension nuts and bolts that need to checked. They are marked in the maintenance manual. May be some one can post an image with torques.
Salim
Old Jan 11, 2019 | 02:00 PM
vlad_a's Avatar
vlad_a
Brake fluid is a bit overdue.
Check sliding pins on front calipers - they have to be lubricated if the vehicle is operated in the rust belt.
That's the only "major" issue I had with my Lexus vehicles of the past.
Old Jan 11, 2019 | 04:02 PM
ukrkoz's Avatar
ukrkoz
Caliper pins have to be moved or lubricated once a year.
You have hybrid. Change ATF in PSD and rear differential. Yes, it's not "required" but is due anyway.
Amphibulus
21
Dec 11, 2018 03:36 AM
diitto
NX - 1st Gen (2015-2021)
Nov 9, 2018 10:42 AM
Keppie
Nov 22, 2012 06:18 PM
quatman67
14
May 7, 2011 09:25 AM
15951
Suspension and Brakes
Sep 20, 2009 05:37 PM
