Hybrid Technology Unique topics related to the 2010 - 2015 RX450H model hybrid drivetrain and other features/options found only on the RX450H. Please use the main forum for discussion about shared components with other third generation RX models.
My RX450H ABS actuator failed! Why won't Lexus fix it?
Old Apr 22, 2022 | 08:06 AM
  #31
salimshah's Avatar
salimshah
25 Year Member
Call your local Lexus parts and give them your vin number and confirm it with them. It is up to you to order the new part from them or not. At times the part you are looking for has been superseded with another part number.
On line Lexus/Toyota parts dealer website can also give you the latest part number. as an example Lexus of South Atlanta and another one is in Arizona.
Salim
Old Apr 22, 2022 | 10:51 AM
  #32
bigbear91's Avatar
bigbear91
Originally Posted by clydo
I got the dreaded C1391 code Abnormal Leak in Accumulator. My mechanic replaced the accumulator and erased the codes but after a day of driving the warning lights all came back on and Freeze Frame Data showed C1391. He says it is time to replace the ABS Actuator module. The part# in my 2011 RX450h is 44510-48080. While searching for the part on ebay and other sites there is also another replacement part# that seems to be compatible - Part# 44050-48320.
Are Parts# 444510-48080 and 4050-48320 intercjhangable, are they the same part or is one an outdated part# and superceded?
My car isnt covered by the warranty unfortunately
Save your receipt. I have a 2013 Rx450h, after I replaced the ABS actuator module in 2020, earlier this year, I finally received a letter from Lexus. Now they have a "customer support program" cover this problem for 2013-2015 RX450h, oand NX300h, (2015-2016) and 2016 ES300h. Dealer would fix this problem for free, and you can submit for reimbursement for out of pocket repair you paid before.
I think Lexus/Toyota know very clearly there is a problem with this part. Just look up for the various "customer support program" they rolled out. Their strategy is for newer model, they would use the warranty to cover it. For older model, well, they just wait it out. When I had the issue, I could see they have such support program for 2009 to 2010 model 450h. Cost saving!!
For cars stuck in the middle, no coverage yet, but I think you just have to pay for it yourself and wait until they "support" your model.
Old Apr 26, 2022 | 09:25 PM
  #33
clydo's Avatar
clydo
Thanks - I've already ordered the part and it is on the way in the post, so ill save the receipt. Hopefully my year will be covered and I can get reimbursed
Old Jun 2, 2022 | 12:00 PM
  #34
Mmagic76's Avatar
Mmagic76
Were there any signs/symptoms prior to your actuator going out?
Old Jul 5, 2022 | 06:53 AM
  #35
desmo907's Avatar
desmo907
My 2013 Rx450h started the "sea lion" noise last year (~114k miles). It is occasional even when car is off. Seems less in cold weather but maybe just because it started last year before winter. Recent rear brakes done and dealer mentioned it was the brake actuator and no safety issue. He casually mentioned about $1k to replace.
I did get the Customer Support Program mail for the brake booster and pump but dealer said not applicable to my car...
I get no lights or codes..... So guess I deal with it... not spending that money (and I am sure its lots more) for a noise ....
Old Jan 24, 2024 | 05:06 PM
  #36
glenn54509's Avatar
glenn54509
2nd gear
Default Similar 2022 450h at 25k miles
have the same issue on 2022 at 22,500 miles. Started about 2,000 miles ago. Told not to worry and have addressed at next service. Took in today and told the whole module had to be replaced. Very disappointed.
Originally Posted by danielle25
Last week, my ABS warning on 2010 Lexus 450H (check ABS) popped up at 107,000 mile, i took it to my local Toyota dealer and they got the error code C 1391 Abnormal Leak in Accumulator Pump and they want the ABS Actuator replaced. My 100K warranty is expired and i am left with no options.
Looking back : My brake actuator always made that ABS chirping sound while the brake pedal was moderately pressed.
I even bought the issue to the west palm beach lexus dealership, but they claimed that this is how the hybrid works!
I contacted Lexus and they asked me to take it to Lexus dealer @ palm beach for diagnosis.
After Spending $400, i get a estimate of $3700 from the dealer.
Lexus is ready to pay $1000 towards the cost of replacing ABS actuator.
I think, there are lot more cases of ABS failing in Hybrids, and somehow they are able to hide it from nhtsa (national highway traffic safety administration).
I couldn't believe that a well engineered car like the Lexus would risk customer safety by using inferior parts!
Old Jan 24, 2024 | 09:49 PM
  #37
salimshah's Avatar
salimshah
25 Year Member
Enjoy the warranty [2022 with 20K miles]. If there is typo in year/milage I can understand sad/unhappy/disappointed but "very"?
Salim
Old Sep 5, 2024 | 11:20 PM
  #38
luckyJ's Avatar
luckyJ
Default Was able to do this in my garage today…took only 5 hours lol
Fairly simple DIY. The only reason this took so long was because this was the first time working on any ABS related repair so went extra slowly/carefully....also, the screw/bolts holding the lines to the actuator take forever to unscrew....and then there are two harness connectors deep inside the engine bay…one near the front of the pump assembly and the other to driver side of the actuator (white clip)…see pictures…by using a straight edge screw driver I was able to pry these loose…once they are free the brackets holding the actuator and pump can be removed…lastly, when you pull the pump assembly out of the vehicle, there is a round clip that is holding the pump to the bracket....this clip you can use a pick tool to bend the fasteners back slightly...just pull and the clip holder will unfasten and you will be able to replace the pump into its bracket....after replacing both parts I bled out all four corners and used a scanner to run the linear valve offset procedure. No more ABS, Brake, and traction control lights on my dash!
here are the part numbers: Actuator 44050-48320, Pump 47070-48060
lohmell
RX - 3rd Gen (2010-2015)
21
Oct 14, 2020 06:26 PM
Miketrae
Apr 21, 2019 09:03 AM
Pyeman
Oct 26, 2018 01:42 PM
RDLGX
NX - 1st Gen (2015-2021)
18
Nov 9, 2015 01:21 PM
marok
Jan 22, 2015 10:15 AM
