Hi guys, has anyone had a problem with a vibration on the gas pedal fixed?Rx400h
Light acceleration from standing resonance vibration coming through gas pedal ,seat and floor Nothing if in EV drive. Roughness in engine sound also Goes away if you lift off the accelerator,comes on again if repeating acceleration at speed
RX400h pedal vibration
Took 18 month. Lexus uk put it down to a characteristic and wouldn’t move. Point is they did not know. As I said 18 month later I got a fault Code to say the hybrid pump was faulty. Changed this pump and vibration dissapeared. Good luck
Jim
Jim
Do you recall, was it the hybrid coolant pump? Also did you happen to get codes from your paperwork?
It was the hybrid oil pump/ 232665. No did not get the codes from Lexus. Hope this helps. Cost in uk £537.39 Fortunately still under warranty
cheers
Jim
cheers
Jim
