Hybrid Technology Unique topics related to the GS450H model hybrid drivetrain and other features/options found only on the GS450H. Please use the main 3GS forum for discussion about shared components with other third generation GS models.
GS450h code P0AE6,U029A and P0A09
Old Sep 26, 2017 | 08:59 AM
lexusisgs's Avatar
lexusisgs
Default GS450h code P0AE6,U029A and P0A09
after removing rubber gourmet from the floor under driver side I could not start my car.
those codes popped out. on the left side there is bunch of wires and orange box that quite possible I had touch it while removing carpet and connection was lost to hybrid battery pack.
Here is what happened:
Old Sep 26, 2017 | 09:02 AM
lexusisgs's Avatar
lexusisgs
Default Visual support.
Old Sep 26, 2017 | 09:06 AM
lexusisgs's Avatar
lexusisgs
Old Sep 26, 2017 | 09:23 AM
lexusisgs's Avatar
lexusisgs
those codes are very unique and gimme a bit of challenge to fight with ECU.
1.
I was checking voltage on battery cells and looks like all of them are 16V very good
2.
I was checking Fan on the hybrid battery just to make sure its working.When I was trying to start car fan was going on,and petrol engine was not starting at all.
3.
I was checking aux.battery voltage ,just to be on safe side and it was reading about 12.9v on freeze frame was shoving 13.00v ....very good.
4.
The code P0A09 DC/DC CONVERTOR STATUS CIRCUIT LOW INPUT, battery state of charge was 58.5 %, trowel position was 18.4% intake air temperature was 91F, ambient temperature was 79F.
So after doing some research on internet I didn't find anything to help me to solve this problem.,Dealer suggesting to change all harness and that is about $3,000.00 ...NO WAY.....
Finally I have decided to kill all codes from history and perform CLEAR CODE OPTION>
when was done I have started car like nothing happened before.
In the conclusion Communication was lost between converter and hybrid battery pack señor I guess and all went in some limp mode .After reset ECU was purged and get all peripherals on side and there you go car is running again.
JUST CLEAR CODE AND THAT IS IT ,BUT note this YOU CAN'T CLEAR CODEs WITH REGULAR OBD-2 CODE READER HAS TO BE TECHSTREAM (in my case I was using version 12.10.019.
Old Sep 26, 2017 | 07:28 PM
XxGoKoUxX's Avatar
XxGoKoUxX
I'm glad you kept the users up to date. I will send this thread right over to the Hybrid subforum. I'm sure other users, if they ever fall into this mishap, can find some guidance in this thread.
Thanks and good job on the follow-up!
thisgtaguy
Aug 31, 2025 10:31 AM
marcilla
Hybrid Technology
Apr 12, 2019 06:43 AM
F250
Hybrid Technology
19
Jan 26, 2018 01:52 PM
hybridbatt
Hybrid Technology
Jul 29, 2015 02:41 PM
94esjag
Oct 27, 2009 12:06 PM
