Hybrid Technology Unique topics related to the LS600h L model hybrid drivetrain and other features/options found only on the LS600h. Please use the main 4LS forum for discussion about shared components with other fourth generation LS models.
Noticeable shudder/vibration when decelerating on ls600hl
Old Apr 5, 2024 | 11:12 PM
  #31
eldee99's Avatar
eldee99
10th Gear
Mine (2008 LS 600h, 90k miles) has the same issue since I bought it last year. Since it was throwing a P0014 code, we have been trying to fix it by getting the engine timing right. P0014 has been resolved but the shudder at deceleration is still there. With my car it happens (or is most noticable) when decelerating at speeds above 40 mph. It only happens when the engine is on and doing around 1000 rpm. It only happens when the fuel pump is active (injecting gas), when fuel pump duty = 0 but engine is running, there is no shudder. I am pretty sure the issue has something to do with the L110 transmission, because GS450h models experience the same issues, and use the same transmission. During the issue, techstream doesn't show helpful data. The only thing that is noticeable is that "multi cilinder misfires" increase at a pace of 10 every second during the issue. This could be caused by the engine rpm that is affected by the shudder from the drivetrain. It doesn't seem to be "real" misfires. Transfer case fluid has been done, sparks and coils, maf sensors, crank and cam sensors. Next week it is going for service and the transmission oil will be done. I've noticed the issue in other LS600h's as well. Some more noticeable than others. In all cases the multi cylinder misfires increase during the issue. I'll let you know if transmission oil will help.
IrishJoe
Hybrid Technology
Jun 6, 2019 10:07 PM
Tec80
Sep 30, 2018 09:56 AM
bebeqq1231
NX - 1st Gen (2015-2021)
17
Nov 28, 2017 11:53 PM
huskies
CT 200h Model (2011-2017)
Oct 18, 2015 08:27 AM
freegard
Jan 12, 2011 11:45 PM
