Hybrid Technology Unique topics related to the 2010 - 2015 RX450H model hybrid drivetrain and other features/options found only on the RX450H. Please use the main forum for discussion about shared components with other third generation RX models.
Crickets
Old Oct 1, 2014 | 05:54 PM
Droid13's Avatar
Droid13
Originally Posted by ericsan13
Can you please cite where you found that current RX450h has Atkinson/Otto switching? I thought this is new to the NX and RC F.
Google searches find that RX450h is Atkinson only and RX450h has VVT-i and not the NX200t's VVT-iW.
Lexus is supposedly bringing D4-S to the RX350, which means it will likely use the 2GR-FSE engine. Is D4-S compatible with the 450h's 2GR-FXE engine?
-Eric
Sources:
http://en.wikipedia.org/wiki/VVT-i#VVT-iW
http://en.wikipedia.org/wiki/Toyota_GR_engine
I think it's all a matter of degrees. Valve timing degrees that is. The Aktinson/Otto switching engines, as Toyota calls them, implements variable valve timing system with a wider range of adjustment on intake (VVT-iW), allowing the engine to breathe ala atkinson. The current RX engine has variable valve timing too, but just the VVT-i which doesn't offer the same range of adjustment.
Swacer
Hybrid Technology
Dec 25, 2014 10:27 AM
TexGS450
Hybrid Technology
12
Apr 29, 2014 07:17 AM
mpbird
HS 250h Model (2010-2012)
Jul 25, 2010 07:33 PM
CAIFAN_64
Feb 23, 2007 06:42 AM
