Hybrid Technology Unique topics related to the 2004 -2009 RX400H model hybrid drivetrain and other features/options found only on the RX400H. Please use the main forum for discussion about shared components with other second generation RX models.
Turbo Charged?
Old Jun 28, 2006 | 04:25 PM
KeepDaBeat's Avatar
KeepDaBeat
Default Turbo Charged?
I'm looking to buy either a RX 350, or RX 400 H. Are either of these engines turbo charged like the RX 300, and what kind of performance could you get out of them if your turbo charged it?
Old Jun 28, 2006 | 06:16 PM
audi2nr's Avatar
audi2nr
toobad the rx300 isnt turbo.............................. neither car you speak of is or will be turbocharged from the factory
Old Jun 29, 2006 | 12:25 AM
Nextourer's Avatar
Nextourer
Heck, the only turbocharged Toyota left is the Caldina.
Old Jun 29, 2006 | 03:57 PM
Lexmex's Avatar
Lexmex
The transmission would be my biggest worry. I don´t know how much Lexus improved these suckers after the RX300 debacle with transmissions (and I have a theory on that debacle).
I plan to do an RX300 turbo in the future, but I need headers and also a transmission upgrade or improvement (which is possible).
Old Jun 30, 2006 | 09:44 AM
KeepDaBeat's Avatar
KeepDaBeat
Thanks Lexmex. At least someone knows that you can turbo charge the RX 300. Oh, by the way, I saw you're RX 300 on car domain, looks very nice. I have a 2001 RX 300, stock. I'm putting in a new sound system right now, but I really want to improve the performance. So, I'm also adding a Weapon-R Secret Weapon Intake, and a cold air box. What else should I do?
Oh, and I'd really like to put a full cat back exhaust in, but I can't find any. I know everyone reccomends this RMM exhaust, but that would just look terrible on a RX!
Old Jun 30, 2006 | 11:08 AM
Lexmex's Avatar
Lexmex
First, the exhaust. Key thing for power is to make sure it is direct flow...the OEM one is definitely not. The RMM is a very good exhaust. I once used an APC (the are some good models of it as opposed to the cheap ones). The key for me was not only that but straightening out the pipe as much as possible, from the resonator to that muffler you saw in the pictures and at the same time widening out the pipe. You will get much more power this way and through any intake.
If I remember my regulations correctly, I do not remember that you have emissions testing in Iowa. A high flow cat, like the one from Magnaflow, will also help out, but the first thing again that must be done is that the muffler must be direct flow.
The Weapon-R intake is not a bad start along with the cold air box, but to take the real advantage of this unit, you need the ram air setup that I or TunedRX300 have, and the easiest way to start on thisis to remove that air resonator you may have seen on my site or in other posts. Then, it can take in cooler air from two different inlets. At sea level, you should have no problem, but at high altitude where I live, I do not run an air filter...it really is that bad up here.
My main recommendations:
Optima Red Top Battery (do this even before stuff like TorqueMaster plugs, Hypervoltage/Hyperground systems from Sun)
Crankshaft pulley (there is a company called Sportivo Concepts that is about to offer a group of 3 pullies (similar to those provided by Unorthodox Racing) to the Solara owners, since the Underdog Racing Development pulley is no longer made, though I know some Solara owners who are pleading to remanufacture them). Do not worry about the Solara, the 1MZFE engine uses the same exact pulley. I was the original guinea pig so you should have no problem
TRD Thermostat (are friends at L-Tuned parts sell this, bit of a pain to put in, but if you do this and add about 2 bottles of Redline Waterwetter, your car will run really cool and the performance shows).
Once Megan Racing is done with their 1MZFE headers, I plan to pick those up and test them on the RX before everyone throws down their $$$.
jscience
Nov 14, 2013 01:52 PM
TEAMxREX
RX - 1st Gen (1999-2003)
Sep 8, 2012 11:54 AM
skyspydude
Mar 8, 2011 03:35 PM
Pat5HKU19
IS - 1st Gen (2001-2005)
Dec 16, 2010 03:39 PM
LexFather
Dec 18, 2006 08:22 AM
