Hybrid Technology Unique topics related to the 2023 up RX model hybrid drivetrain and other features/options found only on the hybrid models. Please use the main forum for discussion about shared components with other fifth generation RX models.
2025 RX 450h+
Old Sep 29, 2025 | 02:13 PM
HuMan321's Avatar
HuMan321
Default 2025 RX 450h+
Hi,
My plugin RX makes a loud clicking noise that I hear while it is parked in my garage while not running, key not near, etc.
The closest I can describe the sound is a very fast relay chattering sound. I thought at first it might be the parking brake which makes a noise but that is a different sound
it has done it numerous times but short lived when I try and get a bead on the area it is coming from
Anyone else?
Thanks in advance
Old Sep 30, 2025 | 05:15 AM
Carbuff2's Avatar
Carbuff2
Many modern cars have timed components that make noises after a period of time...sometimes 6 - 10 hours after a shutdown.
Look to the EVAP system in your search.
Old Oct 6, 2025 | 03:30 PM
John89's Avatar
John89
I have both NX and RX450h+ plug in and does many noises lol. First one is when I first plug it in there click from transformer, and slight one under trunk section. The other is when I open the driver sides door it goes through almost like cycle of clicking noises and then ends after a few seconds. The other are just random noises I hear if I am working in charge which may be cooling fans or heating fans.
I think it is all normal, I am using the 120v wall charger.
Old Oct 9, 2025 | 10:07 AM
StefanoS's Avatar
StefanoS
Originally Posted by HuMan321
Hi,
Anyone else?
Thanks in advance
What you are most likely hearing is the leak detection pump which will cycle after the car has sat for approximately five hours. The car's ECM will perform a self-diagnostic check of the EVAP system, once the fuel system has adequately cooled down. This tests for leaks in the EVAP system and if found, it will throw a DTC. One of the most common ones is a leaking fuel tank cap, which obviously, is easy to fix.
Old Oct 9, 2025 | 10:17 AM
StefanoS's Avatar
StefanoS
The sound that you hear when opening the driver's door is the ABS pump pressurizing the brake system.
Old Oct 9, 2025 | 06:54 PM
wrinkle's Avatar
wrinkle
While we are on sounds, @StefanoS - since you have so many of them figured out () - Is the sound you hear from the engine compartment on turning the 450H+ on in early morning or such in mild-summer days - is that the heatpump's valve reversing from pumping cold air into the cabin configuration from previous day, to pumping heat the next day (with the climate system in Auto mode) ?
It doesn't happen on all days, but the above seems like the culprit ?
Old Oct 10, 2025 | 08:43 AM
StefanoS's Avatar
StefanoS
I am not certain about this one, as I have not really experienced it, to date. I guess that I had better keep my ears open.
olegg66
RX - 5th Gen (2023-present)
Aug 21, 2025 10:31 AM
Nizzy81
Hybrid Technology
Mar 8, 2023 10:32 PM
North
Hybrid Technology
14
Nov 24, 2018 10:11 AM
Mikjr
Feb 18, 2004 10:05 PM
