Hybrid Technology Unique topics related to the 2010 - 2015 RX450H model hybrid drivetrain and other features/options found only on the RX450H. Please use the main forum for discussion about shared components with other third generation RX models.
2012 RX450h Mass Air Flow Sensor (MAF) Location??
Old Apr 25, 2025 | 06:48 PM
Riickk's Avatar
Riickk
Default 2012 RX450h Mass Air Flow Sensor (MAF) Location??
Cleaned up the fuel system (injectors?) on my (2012) RX450h with 8oz of "StarBright" fuel stabilizer in full tank of gas.
My suburban stop-n-go MPG for this Hybrid went from 20-22 to 27.5, and acceleration has increased.
Now I want to clean the MAF, but where *is* it ?? Guessing it must be buried back by the firewall
- somewhere near air filter? Anyone with a photo? TIA.
Old May 5, 2025 | 10:31 AM
tammap's Avatar
tammap
Do you still need help?
Old Nov 13, 2025 | 03:17 PM
Riickk's Avatar
Riickk
Long time since I posted this, but 3 days ago, on start-up got a check engine light. Also, gas mileage has dropped into the 23-25 mpg range.
TechStream identified the problem as a bad or dirty MAF, so, time to clean the MAF, and, then wait to see if it needs replacement.
Again, need to learn where they've hidden the MAF. Is there a YouTube on getting to the MAF on the (2012) 450h?
OR... a write up (with photos!) on getting there. TIA
Old Nov 14, 2025 | 06:09 AM
Clutchless's Avatar
Clutchless
This link explains where it is buried https://www.clublexus.com/forums/rx-...10-rx450h.html
Your RX should be similar to the Highlander that has the same V6 although not a hybrid.
Old Nov 14, 2025 | 09:44 AM
Riickk's Avatar
Riickk
​​​​​​https://www.youtube.com/watch?v=lhUmyob8kPw
If only it were exposed like the 350, it would already be cleaned or changed.
The engine bay on the RX450h is MUCH more crowded, unable to see the Throttle Body, MAF, Master Cylinder, etc.
Old Nov 15, 2025 | 11:14 AM
Clutchless's Avatar
Clutchless
See this thread on the Toyota Nation forum. https://www.toyotanation.com/threads...e-3-5.1799328/
Old Nov 16, 2025 | 07:58 PM
Riickk's Avatar
Riickk
THANKS !! ... Saved me looking all over YouTube.
Ordered a new MAF, and once it's here will be removing whatever I need to to get at the MAF.
I won't change the plugs or coils back by the firewall at this point, I expect them to still hold up to 100-110k,
I'm at about 82k right now.
Och
180
Oct 11, 2021 11:46 AM
2v1g
Sep 29, 2020 05:47 PM
cooltoront
RX - 3rd Gen (2010-2015)
Aug 19, 2016 12:15 PM
RA072724
Mar 12, 2011 11:15 PM
