Seat blowers continuously blowing
Gents,
my passenger seat is continuously blowing cold air out of both the back and the seat holes (the driver seat operates perfectly). It doesn’t matter if the **** is set to off, heat or cold, it is coming out cold.
Also when I turn the switch to either hot or cold, the green light does come on and turns off in the ‘0’ off position.
any help on troubleshooting how to fix this would be greatly appreciated.
thanks,
Ken
thanks,
Ken
You need a new seat heat/fan control switch. The same switch is used in a bunch of different Lexus models and you can find them on ebay for between $50 and $75. I searched HS250h seat heat control.
The old one pops out with a plastic trim removal tool and the wires are easy to swap over. There are older threads here about it.
https://www.clublexus.com/forums/hs-...e-control.html
