HS 250h Model (2010-2012)
Right headlight marker
Old May 20, 2020 | 04:32 PM
AJCalgary's Avatar
AJCalgary
Default Right headlight marker
I have a 2011 hs250h, my right headlight marker (the amber one) doesn't illuminate. I've checked the bulb, looks good. Replaced the bulb and checked the harness. It won't turn on... The left side works no problem. Is this a fuse? Is it a bad wire? Or a more sinister issue?
Old May 21, 2020 | 06:59 AM
Clutchless's Avatar
Clutchless
Have you looked for corrosion in the bulb socket? That is the most likely issue, after having a new defective bulb.
Does the new bulb work when tested on the other side?
Old May 21, 2020 | 07:19 AM
AJCalgary's Avatar
AJCalgary
Thanks for the reply!
There is no corrosion in the engine compartment, none in the bulb holder and the leads look perfect. I didn't check the other side, it's much less accessible without removing that plastic cover.
2010ISF
IS F (2008-2014)
Dec 17, 2015 05:41 PM
Es300Lover
Feb 20, 2013 10:11 PM
GaryP123
Aug 24, 2012 07:42 AM
bearbrew
RX - 1st Gen (1999-2003)
Mar 1, 2010 01:20 AM
reddlexus
Lighting
Nov 3, 2005 07:39 PM
