HS250h Repair / Service Manual
Good morning,
Does anyone have a service or repair manual for the HS? Thanks. E. |
They cost a fortune. This vehicle has the Camry hybrid drive system. Try www.toyotanation.com as more of them work on their cars and you should be able to learn a lot about them. Also look at Green Hybrid dot com
What do you want to know? |
can i get the steps to change flasher of hs250h?
Do you mean the emergency flasher relay?
If so most relays like that are in the fuse box under the hood. A black box to one side of the engine compartment. Once you remove the cover, an guide to the relays and fuses is printed inside the cover. It may also be in the owners manual. If that does not help, I will do a search on my service manual DVD for more information. |
Hs250 h Lexus hazard signal flasher
I think that relay is the one which produces turn signal sound. I have laid down and did locate it in driver dash side above fuse box. The switch for the hazards turns off and onn with techstream testing, with no effect on flashing hazard which is continuous. I got the flasher from Amazon, just seems like difficult job to perform without proper steps because of its location.
see it f we can get a video or steps to properly change that flasher. Thanks [QUO=Clutchless;11417260]Do you mean the emergency flasher relay? If so most relays like that are in the fuse box under the hood. A black box to one side of the engine compartment. Once you remove the cover, an guide to the relays and fuses is printed inside the cover. It may also be in the owners manual. If that does not help, I will do a search on my service manual DVD for more information.[/QUOTE] |
2 Attachment(s)
Attached are the service manual sections on taking the instrument panel apart. I hope this helps.
You may have to get a 2 day membership to Toyota TIS online to learn more about the flasher installation. https://techinfo.toyota.com/techInfo...tis&_nfpb=true |
