#AFEPower #Intake for GX 460
Old Mar 1, 2019 | 04:40 PM
Acrad's Avatar
Acrad
Lightbulb #AFEPower #Intake for GX 460
I'm not one for normally changing my intake up but this was just posted on GXOR.
https://lexusgxor.com/_media/general:afepowergx460.pdf
Old Mar 1, 2019 | 06:21 PM
tigmd99's Avatar
tigmd99
Does more flow = more dirt into engine?
Old Mar 2, 2019 | 04:01 AM
Ncan8's Avatar
Ncan8
10th Gear
https://hs.afepower.com/momentum-lex...r-registration
​​​​​​ I was wondering the same thing too. Does it really work?
Old Mar 2, 2019 | 04:15 AM
tigmd99's Avatar
tigmd99
Personally, no thanks. No reason to screw up my V8. Nothing is free.
Old Mar 2, 2019 | 11:34 AM
ASE's Avatar
ASE
The devil is in the data ... assuming the data is legitimate to begin with. The graphs and footnotes depicted probably do not provide a complete picture ... meaning that this may not be an apples-to-apples comparison.
As an example, this "Cold" air-box may have been dyno'd at 40-degrees ambient, and the "Stock OEM" air-box may have been dyno'd at 95-degrees ambient. While this temperature difference would not explain the total difference depicted, cold(er) air is more dense ... so does provide a level of power boost in any setup or configuration. It does say "Cold" in the product description ... with the run dates being Oct-24th for the "Cold Box" setup and Aug-20th for the "OEM Box" setup ... so no false advertising here !#!
Also note the 275/70 tires on the "Stock Run" vs the (not noted) ... and assumed 265/60 stock tires on the "Cold Air Box" run ... a change in "gearing" between the runs.
Old Mar 5, 2019 | 09:11 AM
danielTRLK's Avatar
danielTRLK
Last edited by danielTRLK; Jan 21, 2021 at 06:56 AM. Reason: Just want comment deleted
Old Mar 5, 2019 | 09:14 AM
danielTRLK's Avatar
danielTRLK
Old Mar 5, 2019 | 09:22 AM
tigmd99's Avatar
tigmd99
Originally Posted by danielTRLK
unlikely the Pro 7 is a better filter than the stock OEM filters.
im going to preorder one and I’ll post results to see how it performs.
Better how? It filters better? It keeps more dirt out of the engine......AND still allows more air to get to engine? If so, then they just found the holy grail of air filters!
Old Mar 5, 2019 | 11:09 AM
ASE's Avatar
ASE
it it was tested at 77 degrees and 86 for stock intake
My real point is that if it were this easy then Lexus would not have withheld ... so either the data is BS or there may actually be a slight performance improvement at the cost of emissions and/or fuel economy ... so at the end- of-the-day you will probably have only gained a cool logo under the hood (no pun intended).
Old Mar 5, 2019 | 04:37 PM
danielTRLK's Avatar
danielTRLK
Yes, I had a customer who was running their Pro Dry S and there was a small continuous reduction of external debris in the engine. Assuming the dyno is an accurate piece of data, then yes, more air, better filtration as the Pro Guard 7 is a more restrictive filter than the Dry S, it's their offroad filter.
While it may seem like a holy grail, the air filter is probably 3 times as much as the OEM filter. There are amazing engine oil filters made of glass media that I used to work with, but only the military could afford to use them.
Old Mar 5, 2019 | 04:39 PM
danielTRLK's Avatar
danielTRLK
I was only referencing you the temperatures.
Lots of easy things OEM's can do, bottom dollar however dictates most things.
I'll try and see if I can dyno this before and after, would be neat to validate the above dyno.
Old Mar 5, 2019 | 05:13 PM
tecman's Avatar
tecman
Is this any different than the K&N option? I had the high performance K&N on an Acura V6 and it was quite loud with acceleration so I would expect even more cabin noise in the GX V8 if that matters to you. Just a FYI.
Old Mar 5, 2019 | 06:23 PM
tigmd99's Avatar
tigmd99
Daniel, are you selling AFEPower stuff??
"small continuous reduction of external debris..." how did this "customer" of yours measure this over time?
Old Mar 5, 2019 | 06:32 PM
danielTRLK's Avatar
danielTRLK
https://www.youtube.com/watch?v=DgLFB5DZpig
K&N uses oiled media, clogs and then can never really be cleaned, proven in labs you can't clean and reuse. Good point about the noise! Didn't even occur to me, Lexus IS big on being quiet.
Old Mar 5, 2019 | 06:37 PM
danielTRLK's Avatar
danielTRLK
No, no selling, just giving out some small information. Oil analysis not available to the public. And upon further thought thanks to another poster, this CAI will probably add a good amount of noise to what is a quiet car. So you are right, trade offs for gains.
