Dual USB ports not working
Old 05-15-18, 05:16 PM
llflyers
llflyers's Avatar
Default Dual USB ports not working
my dual usb not working cigarette lighter port is fine.. does anyone no what fuse it is on 2018 Gx 460. I believe I pulled all 7.5 amp fuses... that are located under the hood.
llflyers is offline
Old 05-15-18, 05:43 PM
hzhao
hzhao's Avatar
If everything else works, it may not be the fuse issue. Given it's 2018 model, I would just take to the dealer to check it out.
hzhao is offline
Old 05-15-18, 05:58 PM
tecman
tecman's Avatar
Some threads to look at.
https://www.clublexus.com/forums/gx-...-not-fuse.html
https://www.clublexus.com/forums/gx-...t-working.html
tecman is offline
Old 05-17-18, 09:28 AM
leftyguns
leftyguns's Avatar
i know for a fact that the fuse is different from the cigarette lighter. the cigarette lighter uses a 15a, im guessing the USB is similar or 10a
the fuse is located inside the vehicle, under drivers side near steering wheel column. the engine fuses do not control this.
leftyguns is offline
konradl
03-04-23 12:26 PM
JSlaughta
GS - 1st Gen (1993-1997)
04-26-13 08:14 PM
SCYAL8R
SC- 1st Gen (1992-2000)
02-24-13 06:37 AM
IamLexus
05-02-10 03:34 PM
Alexbenz
02-28-07 10:33 PM
Quick Reply: Dual USB ports not working
