Dome lights not working
All dome lights not working, i can not find find the fuse box to check fuses, is some one tell me where is fuse locate in 2011 gx460. Thank you
According to page 402 in our manual, it says that the interior lights can be turned on or off by the switch on the overhead panel. So if the switch position is "OFF" then the lights will be off, and not go on when the door is opened. I would check that first.
User21c (02-11-18)
I see you have an ES300. Try posting your question here.
https://www.clublexus.com/forums/es-...3-present-247/
