GX-460 Door #Actuator Failure
Old Oct 20, 2017 | 05:48 PM
ChrisPh's Avatar
ChrisPh
Originally Posted by LabDoc
I have a 2011 GX-460 with about 120k miles. In the past 60k miles, I have replaced 7 (yes seven) door actuators in the vehicle:
- 3 driver door
- 1 front passenger door
- 2 driver side rear door
- 1 back hatch door
After the 3rd actuator failed, I asked Lexus to look into this to find out the root cause of all of these failures with no luck.
On 4, 5, 6, I again asked but got back that there is over a mile of wiring in the vehicle and it's impossible to determine why.
On number 7, the dealer asked that I call Lexus to see what they can do (these are about $650 each to replace and $750 for rear hatch). Lexus said to go see another dealer...
So here I am, out over $4K replacing door actuators and no closer to finding an answer. Anyone else out there with similar issues? I'm at the point of wanting to get rid of it (although I love driving it).
Is you car tinted? I saw lots of tint places used too much water to do a tint job. The water might run down inside your doors and shorted the electrical system and it caused all of your actuator failed. It's just my 2-cents.
Old Oct 20, 2017 | 06:09 PM
Acrad's Avatar
Acrad
IMO... and stated by others....it does seem moisture intrusion through whatever means is likely culprit ...
If one didn't want to do work them self save yourself some money and purchase the part and find a good independent to spend an hour replacing. It should be considerably cheaper.
Example: Driver Door @ $282.77
Heck... with 3rd party market I wouldn't even bother swapping motor... looks like one can get one for $28 here..PN is the same at least
https://www.ebay.com/itm/Door-Lock-A...-/162719493821
Old Oct 21, 2017 | 05:59 AM
Tr6neil's Avatar
Tr6neil
Originally Posted by Acrad35751
I'd be looking into the cheap $5 fix listed earlier in thread. So far no issues with mine. Are you original owner?
I was not the original owner of the GS, and I am not the original owner of the GX. I will look into the $5 fix with my mechanic. We have owned an older GX, 2 4Runners, a Tacoma, and I still have a 2003 Tacoma that never had actuator issues. However, I also had a Camry briefly that had a bad body ECU and those those door locks didn't work either. I hope Toyota engineers are reading these threads.
Old Jul 21, 2018 | 03:33 PM
nwitry's Avatar
nwitry
I had the same issue with my 2012 GX460 (original owner). I had to bring it to the dealership 15 times and had every lock eventually replaced (some locks up to 3 times). I finally determined that it was a design failure and the car posed a hazard to my wife (who drove the car) and my children. I appealed to Lexus to buy back the car via the Lemon Law. After months of discussion, they agreed that there was a significant issue with the vehicle and purchased it back from me in full compliance with the Lemon :aw. I replaced the car with a new 2015 GX460. Last January - while still under warranty - the back gate lock failed. This month (July) it failed again. This is a serious issue Lexus has with the design.
Old Feb 18, 2019 | 06:14 AM
smithpr2's Avatar
smithpr2
Angry Door Actuator
Replaced the front passenger door actuator on my 2012 GX460 last year. Now the driver's door actuator needs replacing. Does Lexus help out with the cost since this seems to be a common problem? Each is about $500 to replace. Thanks
Old Feb 18, 2019 | 06:24 AM
Madtiger's Avatar
Madtiger
Wow, Lexus has this problem?! I thought only German cars have this issue......had it on my BMW and Mercedes!
Old Feb 18, 2019 | 06:26 AM
coolsaber's Avatar
coolsaber
anyone know the failure point on the part? BMWs it was the replacement of the heavy metal actuators for light plastic actuators
Old Feb 18, 2019 | 06:38 AM
Acrad's Avatar
Acrad
https://www.clublexus.com/forums/gx-...r-failure.html
3rd party actuators on eBay are less than $50/each.
PN: 69040-42250
Old Jun 6, 2019 | 07:43 AM
jyarwood's Avatar
jyarwood
Default Lexus GX 460 2011 actuator issues
- 3 driver door
- 1 back hatch door
I have the same issue with my 2011 GX 460. I plan on buying an aftermarket and have a local mechanic fix. I have given up on Lexus and will not purchase another Lexus vehicle. Clearly there is a issue that they are not stepping up to fix.
Old Jul 7, 2019 | 09:55 PM
clearmysix's Avatar
clearmysix
I’ve now replaced all of the actuators on my 2011 GX in the 3.5 years I have owned it. I think one went out prior to me buying it which causes the previous owner to sell it.
Seems like an issue related to this car. However, all the actuators are the same for Toyota and I don’t hear about it being a big problem on other vehicles.
Fortunately I have gotten good at replacing them and the replacements are cheap.
Old Jul 8, 2019 | 05:06 AM
hzhao's Avatar
hzhao
25 Year Member
Glad everything is good for you now. It is highly unusual that all of them failed at very short period of time. Haven't heard any other similar situation in this community. One thing the I am wondering if previous owner had any water damages to causing such failure. Is there any other failure that you had experienced directly or indirectly associated with those failure?
Old Jul 9, 2019 | 01:40 PM
clearmysix's Avatar
clearmysix
I think it is odd too. The previous owner was an older lady, always garaged, San Diego car, no known water damage.
I surf a lot so I often have wetsuits in my car after surfing which increases the humidity in the car. I am thinking this may be the reason? However, the previous owner replaced one after owning it for 3 years so it's not all my fault.
Old Jul 9, 2019 | 04:47 PM
Acrad's Avatar
Acrad
clearmysix: Did they go from working to not in one day or did they start making sounds or intermittently work first? Curious how they fail if it happens.
Old Jul 9, 2019 | 06:26 PM
tecman's Avatar
tecman
Yes please, any signs of failure?
Old Jul 10, 2019 | 10:39 AM
clearmysix's Avatar
clearmysix
Default GX 460 rear door actuator failure - How to fix when door won't open
Hello,
I recently had the rear door actuator fail. It started out slowly having issues, so I ordered the part. When I decided to install the part the door would no longer open so I thought I was screwed. Well, there is a way out.
See the attached PDF for instructions on how to replace the actuator IF you can open the door.
Now that I couldn't open the door this is what I did:
Open the rear hatch
Remove top panel
Remove all other panels (see PDF). I was not able to completely remove the bottom panel but I was able to see that there was a screw driver area at the actuator (RED)
Turn clockwise for a while, this will eventually unlock the door.
Inside the actuator you can see that the screw when turned moves a plate (red arrow), that hits a tab that will unlock the door (blue arrow)
With the door open you can replace the actuator normally.
File Type: pdf
