Interior Door Handle Bulb Replacement
Just notice that the interior door handle light up amber color at night. Have anyone modify this bulb on the door handle enclosure? Any complications removing the door panel or other parts to access the bulb? Last of all, what type of bulb?
Not to complicated. take the trim panel out
look at the door handle from the back of the trim panel.
there is a grey box with a two pin connector that goes to it. unplug and clip out.
The white cover comes off and there is a 3mm led bulb inside. just solder and reverse install.
What are you trying to accomplish,brighter light, different color?
Door panel removal.
https://www.clublexus.com/forums/gx-...-upgrade.html#
Door panel removal.
Door panel removal.
Door panel removal.
antlese
GX - 1st Gen (2003-2009)
12
05-30-15 12:39 PM
