front receiver hitch
Old May 1, 2020 | 03:56 PM
JALinker's Avatar
JALinker
Default Front Receiver
Any resources for a front receiver?
Old May 1, 2020 | 04:23 PM
nuclearn8's Avatar
nuclearn8
There are a few for the 5th gen 4runner you may be able to adapt. Google search for a 4runner, sure it will come up in one of their forums.
Old May 1, 2020 | 05:50 PM
Acrad's Avatar
Acrad
I can't remember a 460 example but here is one one a 470
https://www.clublexus.com/forums/gx-...ver-hitch.html
Old Jul 26, 2022 | 11:32 AM
John00's Avatar
John00
Default front receiver hitch
im thinking of adding a front receiver hitch. Ive seen a gx470 that used a drawtite brand and it worked but im still looking for more info.
has anyone seen a 460 with a front receiver hitch? or have any info on which to purchase and what is involved?
so far what ive seen is that some kits will say don't work but its only because of the front tie down angles not matching oem.
Old Aug 1, 2022 | 03:11 PM
John00's Avatar
John00
i might try this one https://www.clublexus.com/forums/gx-...l#post10589896
anyone know about 460 vs 470 frame in the area shown in the pic?
Old May 11, 2023 | 10:35 AM
ASE's Avatar
ASE
Old May 12, 2023 | 04:14 AM
SPORTMODEL's Avatar
SPORTMODEL
9th Gear
Is this intended to be used for towing the vehicle? Just curious, I don't own an RV but assume this is what the community typically does for all those Jeeps and other light SUV's I see tagging along behind them with kayaks and bikes all over them.
Old May 15, 2023 | 10:32 AM
John00's Avatar
John00
I did order one of those above. Due to a bit lower front installation would at a minimum require cutting a hole under the front license plate installation location. there was also a slight issue with the adapter section to go from the old tie down points to the new points. I've plasma cut the hitch into pieces but haven't worked on it since. Plan is to rebuild it in a way that it will fit nicely without cutting into the bumper cover.
dmdbko
GX - 2nd Gen (2010-2023)
436
Feb 26, 2024 09:21 AM
leslie11
NX - 1st Gen (2015-2021)
12
Jun 5, 2016 02:58 AM
2OnyxLexus
GX - 1st Gen (2003-2009)
15
Apr 5, 2012 01:01 PM
raffiGX
Jun 1, 2009 02:27 PM
