Tapping noise on startup when cold
Old Jul 25, 2024 | 07:39 AM
NewB2Lexus's Avatar
NewB2Lexus
Normal tapping from the valve lifters until they settle. That noise is actually not that loud compared to some other engines not to mention V-twin bike engines.
Old Jul 25, 2024 | 09:43 PM
mountaineer's Avatar
mountaineer
Default thank you
thank you very much for the help .. hope it's normal ..
just did more than 500 miles over 3 days mountain driving
steep / long uphill climbs .. S mode mainly shifting 4th to 3rd .. 2k -3 k rpm s then down again.. tried to "split" the load between engine revs / breaks ..
@3k miles on fresh AMSOIL SS 0W-20 ! to 3500 m..
i have to say this oil is impressive !!!!! ..
what you all think about it !? it's my first time using it
( despite my old age!!).. disregarding $$cost + it's a overkill for 5k oil changes .. disregard that ! what do you all
think of the oil performance + Long term use !??
what are the reasons ( others) stay away from it !?
and What's tge deal with ( rumors) it being bad for NA V8 ENGINE !?? I'd appreciate any comments
thank you ..
Old Jan 5, 2025 | 09:25 PM
treilly1's Avatar
treilly1
7th Gear
That’s actually not a normal noise and it sounds like you should check the timing cover in the front for leaks. That tick that fades away is from the lifters and low oil. Mine does not make that noise on start up , but I test drove one before that made that exact noise and ended up having to have the lifters replaced because it was leaking oil over time and they were running it with low oil.
mlaman
Apr 10, 2018 05:12 PM
DocT
LX - 3rd Gen (2008-2021)
23
Jun 19, 2016 03:44 AM
RXGS
Apr 18, 2015 07:57 PM
mel's-gs
Nov 25, 2011 08:24 PM
Jmai22
GS - 1st Gen (1993-1997)
Feb 13, 2003 02:53 AM
