Which wire controls switch backlighting?
Old Feb 8, 2020 | 10:16 AM
dwh13's Avatar
dwh13
Default Which wire controls switch backlighting?
I recently installed a front camera and a light bar - the camera switch is backlit like the rest of my switches, but the lightbar switch has to be connected to one of the others to be backlit. The problem is I'm not sure which of the stock wires to tap into. Anyone with an FSM or wiring diagram able to tell me which wire to either the headlamp washer button or the VSC button controls its backlight? Cheers!
Old Feb 8, 2020 | 12:49 PM
OCGX's Avatar
OCGX
The illumination for the switch should be green for the positive. Gray is the ground that goes to the illumination control computer and rheostat. Your switch might need to have a separate led ground to work?
Old Feb 8, 2020 | 02:58 PM
nebrou's Avatar
nebrou
Which front camera system did u use?
Old Feb 8, 2020 | 03:39 PM
dwh13's Avatar
dwh13
Thanks y’all, the green wire was the one!
Old Feb 8, 2020 | 03:41 PM
dwh13's Avatar
dwh13
Check this post on my build thread, I've got links to everything I used for the install!
NourasElia
Mar 31, 2017 11:53 PM
mk4r34
Feb 22, 2012 09:39 PM
Superjatt
Jan 24, 2012 08:32 PM
jishan
RX - 1st Gen (1999-2003)
Feb 23, 2008 08:21 AM
