OEM: #Rear Seat #Entertainment System- ( #RSES ) Questions & Discussion
Old Jul 24, 2019 | 07:58 PM
gbell210's Avatar
gbell210
Originally Posted by John00
i think GROM sells some stuff that can do this.
you can also tie into the line, maybe use a powered splitter if theres impedence issues. you will need to be comfortable ripping into cabling and reading wiring diagrams
nav/dvd override is possible with a few different methods. theres a thread somehwere on that.
Is there a location to download the EWD, to find an external input lead? I meant output leads.
Old Jul 25, 2019 | 04:33 AM
Acrad's Avatar
Acrad
Bypass instructions here
https://www.clublexus.com/forums/gx-...heap-pics.html
https://lexusgxor.com/
Old Jul 25, 2019 | 04:22 PM
John00's Avatar
John00
yes and no
yes theres a download somewhere, not sure where exactly, that has it
no theres not an external input lead (that i can remember) you will have to get creative in interfacing to the wiring
if the impedences are close enough and high enough on the inputs, a simple splice might work.
something like this might be better for you, it has hdmi in, av in, also outputs, along with a bunch of other stuff:
MicroSD, HDMI/AV1/AV2 in for video and backup camera
Up to 3840x2160 display output for HUD or rear seat displays
https://gromaudio.com/store/vline/le...n-upgrade.html
Old Nov 14, 2019 | 06:18 AM
JALinker's Avatar
JALinker
Question RSES Remote
Just acquired an '11 Premium with RSES... no remote provided nor headphones... I am not so much worried about the headphones, as I can (I assume) make the audio play through the regular audio system, right?
But the remote? Each unit is set on AM radio and I don't think there is a way to change it without the remote... is there a universal remote I could use/program to use? The replacement remote is pretty expensive...
Any guidance would be appreciated... searching for "remote" here most only turns up threads on remote start or key fob remotes...
Thanks!
Old Nov 14, 2019 | 06:21 AM
cb1111's Avatar
cb1111
Thanks!
There was a thread either here (in the LX forum) or on iH8mud that talked about how to use a universal remote. There was a specific cheap one from Amazon that worked. I'll post if I find it.
Here you go.
I assume the GX is the same.
Old Nov 14, 2019 | 06:52 AM
JALinker's Avatar
JALinker
Thanks for the fast reply-- I will look into this--the guidance to go to Logitech to get them to create a profile is a great idea--I have asked that at Logitech just now...
Thank you!!
Old Nov 16, 2019 | 05:22 PM
Randy B's Avatar
Randy B
This is the one I had in my 2014 GX460:
https://www.ebay.com/itm/2013-2014-2...temCondition=4
Randy B
Old Nov 17, 2019 | 07:23 AM
JALinker's Avatar
JALinker
yeah-- I have seen those, much cheaper than the ones prior--I think that remote you linked is for 14 and up. Thanks!!
I found a lady in Utah that had 2 for $100 on OfferUp, but she hasn't responded to my emails...
Old Dec 13, 2019 | 08:21 AM
bbqsoup's Avatar
bbqsoup
Not sure if you’re still looking for the remote but there’s someone listed one for sale on facebook gx forsale section for cheap.
Old Dec 13, 2019 | 11:25 AM
JALinker's Avatar
JALinker
Thanks! I guess, though, I am too thick-headed to find it. I can't find the "For Sale" section of GXOR on FB
Old Nov 27, 2020 | 09:17 AM
Acrad's Avatar
Acrad
Old thread resurrection but wiring pinouts
Old Jan 9, 2021 | 12:37 PM
Acrad's Avatar
Acrad
Based on 2020 & 2021 brochures RSES is no longer an option on 2021 Luxury.
Last year for availability was on a 2020 Luxury trim
Old Feb 6, 2022 | 06:27 PM
bl4d3z's Avatar
bl4d3z
Default Rear Entertainment Sources
I can’t seem to figure out, how to use different sources on the rear entertainment system.
no matter what I source I choose on one, it also changes it on the other.
I’ve tried to look this up in the manual and other searches but can’t find the answer to this.
Old Feb 21, 2022 | 01:19 PM
bl4d3z's Avatar
bl4d3z
Bump, anyone ?
Old Feb 21, 2022 | 02:25 PM
IanG's Avatar
IanG
The instructions for the rear entertainment is in the Navigation Manual
You can try this link (change the year at the top) https://drivers.lexus.com/lexusdrive...als?type=omnav
