Rear View Mirror
Old Oct 8, 2019 | 04:45 PM
xf30ul's Avatar
xf30ul
Originally Posted by Acrad
Ok... I was under assumption existing mirror was plugged in. It does require power. IMO stock mirror would plug into that connector.. At least on my ‘12 and the spare AHB model there is a wired extension piece that goes from the mirror assembly to the vehicle wiring harness,
Got it. Apologies for the confusion.
Old Dec 24, 2019 | 08:30 AM
JALinker's Avatar
JALinker
The HomeLink in my 11 is not "current" enough to work the openers at my home... Will a later model mirror work in the my 11?
I have also looked at removing the center overhead console and replacing it with a later model one without HomeLink buttons and then adding aftermarket HomeLink to that replacement console...
Amazon Amazon
Old Dec 24, 2019 | 09:49 AM
Acrad's Avatar
Acrad
JALinker: That would probably be the most cost effective replacement assuming it is compatible.
zes
Jan 11, 2016 10:11 AM
skassamali
Oct 18, 2011 01:21 PM
PFB
Aug 31, 2010 08:27 PM
