OEM AT #Cooler Install - #transmission
Old Jun 8, 2021 | 02:47 PM
  #136
Acrad's Avatar
Acrad
#2 is the torque converter outflow so it will get hot.
What are your #1 pan temps peaking out at?
Old Jun 8, 2021 | 02:49 PM
  #137
BPGX460's Avatar
BPGX460
about the same, 2 to 3 degrees less
Old Jun 8, 2021 | 02:52 PM
  #138
Acrad's Avatar
Acrad
That seems warmer than I am used to. Do you know if you are in AT lockup? There is a gauge called "Status of the lock up" in OBD Fusion/Link.
Another thing you can try is pinning the AT fluid thermostat open if you want to do a temp test to see if that drops temps.
Old Jun 8, 2021 | 03:22 PM
  #139
BPGX460's Avatar
BPGX460
What is status lock up? Just took it for short drive, at2 temp peaked at 212 degrees at1 peaked at 93...but mostly stayed around 91 (guess i was wrong about at1 before) status lock up did report a 1 briefly a few times....coolant and engine oil stayed between 91 and 95
Old Jun 8, 2021 | 03:29 PM
  #140
Acrad's Avatar
Acrad
It tells you when the torque converter is locked up. 1=locked / 0=unlocked
You will generally see cooling when locked
Old Jun 8, 2021 | 03:34 PM
  #141
BPGX460's Avatar
BPGX460
You think i should be changing my fluid, or is this normal?
Old Jun 8, 2021 | 03:58 PM
  #142
Acrad's Avatar
Acrad
IMO: If temp #1 is normally at or below 200 cruising around you should be fine.
Old Jun 8, 2021 | 04:01 PM
  #143
clearmysix's Avatar
clearmysix
How does one monitor the temp?
Old Jun 8, 2021 | 04:11 PM
  #144
Acrad's Avatar
Acrad
I use OBD Link with this adapter. It isn't the cheapest but works well with app, adapter gets regular firmware updates but it can also read TPMS data on the 460. IMO: It's like a portable Techstream for troubleshooting too.
https://www.obdlink.com/products/obdlink-mxp/
https://www.clublexus.com/forums/gx-...and-gx460.html
Old Jun 8, 2021 | 09:19 PM
  #145
LexusGXFan's Avatar
LexusGXFan
This past weekend we had near record temps in MN.
On the outside temp display on the GX Dash, it showed 100 degrees. ATF #1 was running around 202F and ATF #2 was spiking around 215F in stop and go highway road construction traffic and both temps equalized (as the do) while cruising at 75 MPH at 202F.
I don't have the Cooler.
Engine oil also was at 202F.
Old Jun 8, 2021 | 09:28 PM
  #146
Acrad's Avatar
Acrad
On post 36 I have a graph of my stock versus cooler and pinned thermostat on a drive to and from destination over local mountain pass.
https://www.clublexus.com/forums/gx-...l#post10553548
Old Jun 9, 2021 | 05:33 AM
  #147
nuclearn8's Avatar
nuclearn8
I didn't monitor but I know the cooler was working over I-40 thru the smoky mountains this past roadtrip... I had the cruise set at 80 mph, suspension on sport mode and she was just hauling (for an SUV) thru the curves... so silky smooth.
The tranny cooler is the best mod, besides the rear door table, I've done to our GX.
Old Jun 9, 2021 | 08:31 AM
  #148
Lavrishevo's Avatar
Lavrishevo
Come get yours while it’s hot, literally.
https://www.clublexus.com/forums/market/968013
Old Jun 9, 2021 | 11:49 AM
  #149
SamLexRXGX's Avatar
SamLexRXGX
Hi All,
Yesterday I towed 4000 pound trailer in sports suspension mode and automatic transmission for 200 miles. I got ATF 2 temperature peaked around 230 some time and most of the time around 210. I do not have the auxilary OEM or aftermarket transmission cooler. with out trailer I had ATF 2 around 205 to 200. is ATF 2 temperature 230 is very bad?
Do I need OEM cooler or after market Hayden 678 or 679.
Thanks.
Old Jun 9, 2021 | 11:53 AM
  #150
BPGX460's Avatar
BPGX460
Originally Posted by SamLexRXGX
Hi All,
Thanks.
My ATF 2 hit 225 this morning driving on the highway to work...with aux cooler and no trailer...but was going up somewhat of a grade...cruise control set to 75+ mph...so i think yours looks better than mine
I dont remember what My ATF 1 temps were, but i think it stayed around 200.
