Engine Air Filter fitment 17801-38051 vs 143-3025
Old 01-24-18, 10:48 AM
bbqsoup
bbqsoup's Avatar
​​​​​​​Here’s a pic of with and without the foam. Both are Toyota OEM made by Denso.
Old 01-24-18, 12:48 PM
cicio
cicio's Avatar
Yea, I have used both and didn't notice any difference myself. Just curious if there is any difference on performance and filtration.
Old 01-24-18, 03:51 PM
Acrad
Super Moderator
Acrad's Avatar
Received 3,570 Likes on 2,337 Posts
Mine had one with the foam on it... I replaced with a non-foam unit.
Old 10-13-18, 02:55 PM
Acrad
Super Moderator
Acrad's Avatar
Generally a simple procedure to swap air filter but not everyone is a DIYer but this may give some confidence to do themselves who don't normally perform maintenance on their vehicle.
https://www.carcarekiosk.com/video/2...engine/replace
Old 05-03-19, 07:21 AM
NewB2Lexus
NewB2Lexus's Avatar
Default Air filter
Wanted to ask why the air filter the GX was originally delivered with is different than the one we put in. The original one seems to have an extra layer but not sure if it serves any purpose.
Old 05-03-19, 08:52 AM
Moonlite
Moonlite's Avatar
Just bought OEM filter and it came with extra layer as original. Yes I am curious too. I didn’t see any other filter like this.
Old 05-03-19, 09:18 AM
bbqsoup
bbqsoup's Avatar
Yeah noticed the same when replacing mine. The extra layer probably there to help make it a little quieter but not sure. The Toyota OEM I got doesn’t have it. Since then I replaced it with a dry filter and keep the original as spare when I wash the permanent filter.
Old 05-03-19, 09:40 AM
John00
John00's Avatar
You can order the one with the extra filter if you want. sometimes the extra part is able to stop large things from going through a worn or wet area of the filter paper section.
some other versions use a metal screen. which you should get depends on your driving environment and maintenance schedule.
Old 05-04-19, 05:58 AM
Yurka
Yurka's Avatar
Same, i replaced mine last week actually, it had an extra layer but i switched to K&N
Old 05-06-19, 12:56 PM
Stepsride
Stepsride's Avatar
It looks like a foam pre-filter. It will prolong your filter especially in very dusty areas. I have seen these pre-filters on snorkels and HP intakes. It is just a guess by the way
Old 04-01-21, 03:46 PM
LexusGXFan
LexusGXFan's Avatar
Default Engine Air Filter - Two Choices
Does anyone know what the differences are between the two engine air filter choices available from Lexus?
Looks like the same parts for 2016 and 2019 MY
1780138051
and
17801YZZ13
I was sold the latter at my local dealer, but didn't know two choices were available.
Thank you!
Old 04-01-21, 04:32 PM
JayPixelGX
JayPixelGX's Avatar
Looks like 1780138051 is OEM Lexus air filter and the other is for 4runner a d FJ but can be interchangable between the two.
I have 1780138051 in my 17
Old 04-01-21, 05:28 PM
BigLClub
BigLClub's Avatar
https://www.ebay.com/p/655463543
Amazon Amazon
Old 04-01-21, 06:15 PM
xychromo
xychromo's Avatar
Here’s the difference, the Japanese version has the coarse foam ‘pre-filter’, the USA made version does not.
bbqsoup (04-01-21)
Old 04-01-21, 06:38 PM
BigLClub
BigLClub's Avatar
The WIX I ordered had the "Pre" filter. Thought it was a nice touch.
Weird thing is the 4.6L in the Tundra...takes a different filter.??
Quick Reply: Engine Air Filter fitment 17801-38051 vs 143-3025
