Just to confirm, DF is 4.5 qts without pandrop, but with pan and filter it should be?
Rough figures of course
My drain /fill leaving pan in place came to 3 qts or so as read on the pitcher I drained it into. I put 3.5 back in and then set the level per the procedure. I had the truck on 4 ramps.
Put front of car on jack stands and drained 3.25 qts. Leveled car, then put in 4qts. Got 0.5qts out from overflow.
Thanks all for responding.
Side note, i like using Amsoil's spec lookup for rough estimation:
Capacity: 6 speed With Atf cooler A760F Total Fill 11.8 quarts.
Capacity: 6 speed Without ATF Cooler A760F Total Fill 11.6 quarts.
Capacity: 3.2 quarts Initial Fill.
interesting how close they are to actual owners service history
