#Water #Pump #Leaks or failure
Old May 28, 2019 | 08:50 AM
  #61
xplorr's Avatar
xplorr
Originally Posted by Ramacher
If it's leaking that much, I'm fairly certain it's your water pump. After I noticed my leak my coolant tank was going down about an inch every week. Since swapping out the water pump I haven't noticed it go down.
Theweep hole for the water pump is behind the pulley at around the 4 o'clock position and really hard to see without removing the pulley. I noticed the coolant in the valley after I removing my air intake box, tube and throttle body.
Now I'm not 100% certain if the coolant in the valley is from the coolant valley leak or coolant coming from the water pump weep hole and being blown up and into the valley by the fan. I'm keeping an eye on my overflow tank but when I checked it last week it was still at the full mark.
Thank you for the feedback. I'm glad yours turned out to be the water pump, as it sounds like that is an easier fix than the valley leak.
Old Nov 23, 2019 | 12:37 PM
  #62
natehack's Avatar
natehack
Bumping this old thread since I’ll be doing this service soon! Thank you past users for part numbers.
$1450 quote at the dealer was too much to eat. At $240 so far for Aisin pump, Gates belt kit, and Aisin thermostat.
Anyone with torque specs for the water pump?
Old Nov 2, 2020 | 04:44 PM
  #63
Beastman's Avatar
Beastman
Default Water pump 16 gx 460
when should I expect to replace water pump and how much could this repair cost.
thanks in advance.
Bill
Old Nov 2, 2020 | 05:49 PM
  #64
nuclearn8's Avatar
nuclearn8
I plan to do it at 100k with new radiator, hoses and thermostat. Not sure what parts would cost. Havent looked it up...
Old Dec 6, 2020 | 12:37 PM
  #65
Acrad's Avatar
Acrad
https://static.nhtsa.gov/odi/tsbs/20...83269-9999.pdf
Old Apr 12, 2021 | 08:11 PM
  #66
dubya3232's Avatar
dubya3232
Default Low coolant gx 460
Just purchase a 2015 gx with 120,000 miles from a local dealer. Car is in great shape for age and mileage. Drove and handled well with no obvious defects. Dealer does a used car inspection and with Lexus reliability record I figured that beyond some typical used car sorting out i would be in good shape for miles to come. Needless to say I get home with the car and discover that the coolant is very low. None in the overflow and low in the radiator as well. This alarmed me and I did some research on this forum and learned about some of the coolant leak issues these trucks can have. I returned to the dealer and we looked over the truck in the lift and could not find the source of the leak. They seemed to brush it off as no big deal. My fear is that I may have a valley plate coolant leak deep in the engine that we may have missed. Are there any other explanations for the low coolant level? Radiator cap ? I have an appointment with Lexus to have an inspection/service and for them to pressure check the coolant system. A small timing cover leak was also found which I was told was not worth the fix and of no harm. Thanks for the help in advance. I am really looking forward to enjoying the truck and not stressing about it.
Old Apr 12, 2021 | 08:27 PM
  #67
Manh3's Avatar
Manh3
I hope you don’t have a coolant leak or valley plate issue but if you look underneath the truck you should
pink dry spot stains from the coolant leak. I’m assuming the truck is for taking your family around or used as an adventure mobile, I would not go anywhere far until I have the coolant system checked out and corrected because your truck overheating while in the middle of nowhere is not safe.
Old Apr 13, 2021 | 06:39 AM
  #68
John00's Avatar
John00
you can have a very small leak and not be concerned. after a refill of the system, check the tank after a week, then a month, then 3 months so you can know how much is leaking.
maybe the previous owner never ever checked it, so theres 7 or 8 years of loss.
ive had mine about 5 years, and had to add coolant 2 times, each added less than 1/4 qt.
small amount of dried coolant visible when changing the oil, more towards the firewall and back of engine on bottom, not near the radiator.
Old Apr 13, 2021 | 07:20 AM
  #69
xychromo's Avatar
xychromo
I was concerned about a leak when I first got my truck and have been closely monitoring the fluid level on the expansion tank ever since. Draw a line on the tank at the level of the fluid, when truck is cold, and check that level periodically. Mine hasn't dropped in over 4 months and about 5k miles so I think I'm good for now.
Old Apr 16, 2021 | 02:47 PM
  #70
dubya3232's Avatar
dubya3232
So it has been a week now and the coolant has dropped from full to low. I am returning to the dealership tomorrow to discuss with them. What recourse do I have being the presented the car as inspected when a simple coolant check would have unveiled that there is a major issue going on?
Old Apr 16, 2021 | 04:40 PM
  #71
Acrad's Avatar
Acrad
Are you able to see anything pink on underbody of vehicle from front to back of engine?
Take a mirror on rear side with a flashlight as well.
Old Apr 16, 2021 | 04:49 PM
  #72
dubya3232's Avatar
dubya3232
I haven’t been able to find any evidence of an external leak. The truck seems to be running well. No rough idle, smoke, oil looks good.
Old Apr 16, 2021 | 04:52 PM
  #73
Acrad's Avatar
Acrad
How does the oil and coolant look? Can you take some pics?
I'd only pull off radiator cap when completely cooled.
Old Apr 18, 2021 | 11:47 AM
  #74
BigLClub's Avatar
BigLClub
2 types of leaks for the 4.6: Water pump and engine valley.
Info
https://www.google.com/search?q=toyo...hrome&ie=UTF-8
Images:
https://www.google.com/search?q=toyo...w=1396&bih=657
Old Apr 18, 2021 | 02:30 PM
  #75
Acrad's Avatar
Acrad
Assuming you don't have a head gasket issue you can also check coolant valley with borescope camera.. not 100% coverage but if not leaking over the back may be a better indicator as there could be evaporation before it makes it to the rear of engine.
IMO: Water pump leak on this scale of loss should be really easy to spot.
https://www.clublexus.com/forums/gx-...l#post10922217
