noise coming from passenger air vent (video)
Old Dec 29, 2025 | 10:08 AM
ESrob's Avatar
ESrob
Question noise coming from passenger air vent (video)
I noticed a 'whirring'/ 'buzzing' sound coming from the passenger side air vent, can anyone identify what is causing this noise or if it is normal?
Video: https://www.dropbox.com/scl/fi/te9b5...nf519qo5b&dl=0
2023 GX @ 35,000Miles
Old Dec 29, 2025 | 02:19 PM
BradTank's Avatar
BradTank
Not sure if this is the issue, the video is a little hard to make out.
But I had to replace the HVAC fan assembly on my GX because it was making odd noises, almost like a bearing had gone out. Kind of a clicking noise. It was actually a pretty straightforward repair, bought the whole unit and replaced myself. You didn't have to tear out the dash, went under where the glove box was. Unit itself was around $300. Car was just outside of warranty, service advisor was dismissive when I first brought it up.
After I replaced it, the noise was gone and it sounded like it should. I probably didn't even need to replace it, I was the only one it bothered. Wife largely couldn't even hear it.
I'm assuming you've already checked the filter and replaced, in case there's some debris in there.
Old Dec 30, 2025 | 04:42 AM
iwashmycar's Avatar
iwashmycar
You open up and check the cabin filter for debris? Make sure there isnt something in the fan down there.
Old Dec 30, 2025 | 12:10 PM
ESrob's Avatar
ESrob
thanks for the replies, taking it in to the dealer later this week. will update here with what they say
Old Dec 30, 2025 | 10:26 PM
Toejab's Avatar
Toejab
even though your vehicle obviously would still be under warranty I wouldn't waste my time going to a dealership prior to just checking out that cabin air filter all you do is open up your glove box and it pulls right out with very little problem figuring out how to pull it out and then the fan is right there. Why waste time going to a dealership or if you don't have to
Old Jan 5, 2026 | 12:00 PM
ESrob's Avatar
ESrob
Resolution:
The blower motor was replaced under warranty. If anyone has a similar issue, I would explain the issue as a constant buzzing noise while the fan is on. One easy way to show it to a technician is by setting the fan on the lowest fan speed while the car battery is on but not the engine. Toggling between the lowest fan speed and turning the fan off completely makes the sound obvious for a technician to understand. I had to be a bit persistent as the first technician and service advisor said they didn't hear anything abnormal. I suspect it was because the technician working on the car was checking in the loud garage. The service manager was able to pick up on the noise almost immediately and identified it as the blower motor.
Mzbloushi
Mar 27, 2024 07:33 AM
lexsy
Dec 11, 2023 08:19 AM
Dbrown672
GX - 1st Gen (2003-2009)
Jan 4, 2020 06:44 PM
Nixcision
Nov 7, 2019 07:12 PM
CCJ22
Feb 4, 2013 02:36 PM
