#Coolant level low
Old Sep 18, 2024 | 10:29 PM
Henry23's Avatar
Henry23
1st Gear
Default #Coolant level low
In today’s 11AM, I noticed my coolant reservoir almost bottom, I add some coolant in there and drive about 20 miles, and I checked the vehicle at 6PM, vehicle still little bit hot, the level is lower than before, and 10PM, I checked again, the level is almost bottom again, nothing on the ground and radiator, and don’t have any symptoms of valley plate leaking. Still confused
Old Sep 19, 2024 | 05:27 AM
xychromo's Avatar
xychromo
It's harder to diagnose a valley plate leak, need a boroscope to confirm if you don't see any residue rear of engine or on the ground.
Old Sep 19, 2024 | 10:28 AM
texas008's Avatar
texas008
same thing happened to my 2014 GX460 couple months at 95k miles.
it was the radiator or radiator cap (pink residual on driver-side of radiator). I replaced the radiator and then problem solved (so far)
Old Sep 19, 2024 | 11:00 AM
OhioGX23's Avatar
OhioGX23
Interesting observation as I have a 2023 GX w/ only 7K miles and I check my coolant yesterday and it was below L. Added some and seems to be fine. Wonder if its evaporation. Looked underneath and no leaks I could see. Running fine so who know.
tanstaafl
Aug 19, 2024 11:55 PM
marvin5881
Aug 16, 2023 05:45 AM
TriniLex
Jun 27, 2023 10:55 AM
akafixture
Oct 4, 2018 08:29 AM
Brutus213
Feb 20, 2017 12:35 AM
