GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
HELP! Need part numbers for knock sensors and harness
Old 11-03-20, 05:07 PM
golfindude
golfindude's Avatar
Default HELP! Need part numbers for knock sensors and harness
Howdy all, apparently a rat chewed through the knock sensor wiring harness in my 2004 GX470. Trying to find the part numbers for the sensors and wiring harness. May as well replace the sensors while I've got the intake manifold off.... Can anybody help? Thanks in advance!
Old 11-03-20, 05:42 PM
tz693
tz693's Avatar
https://parts.lexus.com/p/Lexus_2004...961552010.html
Old 11-03-20, 07:01 PM
golfindude
golfindude's Avatar
Thanks tz; but this diagram shows two different sensor types, as I've seen in various web searches. One is more of a "barrel" design that screws in, the other looks more like a chubby washer with a wire connector. Do the different banks have different knock sensors, or will either work? We bought out GX in 2003 as a 2004 model; not sure if that makes any difference. Also, any part numbers for the actual harness? Thanks!!
Old 11-04-20, 06:50 AM
Lexus4321
Lexus4321's Avatar
The 2003-2004 GX uses this screw-in OEM sensor.
89615-52010 (11/2002 - 10/2004) , xRef list here http://www.kakapart.com/search/defau...ch/89615-52010
see http://www.kakapart.com/parts/intera...961552010.html
2005 model started a new # with a bolt on sensor
89615-20090 (11/2004 - )
The wiring for the sensors comes out of the main wire harness and attach via a connector, so are you looking for just the connectors to make repair? Any pics of the wire damage?
Old 11-04-20, 02:33 PM
chiph9
chiph9's Avatar
Toyota/Lexus made running changes to the GX during production, so you need your VIN to definitely know which to buy. Or you could take a photo of the bad one and compare it to the parts sites.
Chip H.
Old 11-04-20, 03:24 PM
Lexus4321
Lexus4321's Avatar
Chip H.
I pulled the part # from a Toyota parts site I subscribe to.
There's only two types, one for 2003-2004 models, and one for 2005+
If the sensors need replacing or will be replaced, then why not take the intake off and just take a look ?
BShahi
ES - 6th Gen (2013-2018)
11-03-20 04:51 PM
gu3rr13r
05-18-17 12:04 PM
dogwisper
Performance & Maintenance
03-12-17 01:06 PM
ViPeRs103
06-19-14 08:50 PM
99jewel
RX - 1st Gen (1999-2003)
07-13-08 04:46 AM
Quick Reply: HELP! Need part numbers for knock sensors and harness
