How many MILES on your GX TODAY? What year? Repairs done?
I test drove quite a few 460s when we were looking for a new vehicle for my wife. I was dead set on having two GXs until we started driving them. The handling, engine, and transmission all seemed seemed fine, but I was incredibly disappointed with the dated interior. We started looking at the 2013 because it was the last year with the front end we both preferred, but quickly went newer, even looking at a brand new 2017 (at the time) hoping to find something more updated. No luck. The nav screens and buttons looked like they were a decade old at best. Everything about the interiors seemed to be old, especially compared to the 2017 RX and LX models in the showroom at the time. We ended up buying a one year old X5.
2006 Nav - 170K
I just bought it a month ago, but replaced the radiator, timing belt, pump, all fluids, and about to get the clunk taken care of with a new drive shaft.
Pretty sure she will be sweet after that for a while, love it.
Replaced the Radiator upon purchasing the GX as preventative Maintenance, all new fluids and filters, and that's it so far. The only thing not working after driving it now for about a week is one of the rear window switches on the drivers door. The switch at the rear window works, so it's probably a bad front switch, no big deal. Will save that for a rainy day to fix.. After reading about the dash crack issues, I did a close inspection, and did find a few small cracks that are out ot normal sight. So is there a recall to replace the dash for free, or is it my expense. Is there anyone who has paid to replace their dash, and how much did it cost? Right now the cracks are so small my wife hasn't noticed them, and she is super critical. I think I'll use her as a gage when to replace it, if it is a costly item. Also, has anyone replaced the dash as a DIY project?
Couple of other things, My 06 GX does not have NAV, and I'm thinking about a rear camera setup. Has anyone added a rear camera setup, what type and how much?
Also I ordered a frame hitch with wiring, and after reading the manual today, it said there are wires preinstalled for the trailer connector under some panel. Does anyone know what panel their talking about and how to access them?
Here is a actual quote from the manual:
"Your vehicle is equipped with a wire harness stored in the rear end under-body. Use either of them to connect and operate the trailer lights."
Odd wording, "stored in under body", and "use either of them", sounds like there are two to choose from...
Just trying not to reinvent the wheel, has anyone searched and found these wire harnesses?
Thanks
Thanks
I seem to recall looking up the price of the dash - in the $1200 range for the part?? Maybe? Labor is going to be the killer on it.
Mine had the pre-wire, and it had the 7-pin RV connector on the back already. Did not have a 4-pin connector.
Chip H.
Chip H.
outrbnks (03-18-18)
outrbnks (03-18-18)
2003 GX470; Dorado Gold, Tan interior.
202,460 Miles
Nav/Mark Levinson/Rear Entertainment/Three Row
One timing belt at 110,000
All oil and service up to date
Air suspension failed at 200,000=replaced with springs and conventional shocks (~$800)
Amplifier failed, replaced with OEM one for $400
Only issue that has left me stranded was the shift linkage that snapped due to rust, cost $400 to fix (incl. labor)
Gas mileage on city about 14-15 mpg.
Gas mileage on highway going 85mph: 17mpg going 65mph: 20mpg (with two other passengers and 300lbs of luggage) (based on several road trips)
I have some minor issues that I haven't fixed yet like the inner tie rod boots are torn and a power steering hose is leaking from the engine bay. There are also two leaks from the transmission engine seal and the drive shaft seal.
There is a good amount of rust that I have coated with POR-15, used two quarts which was $80 (did the whole undercarriage)
Battery died after 3 years, replaced at 50% off under warranty ($140 incl. labor)
About $1600 in repairs and $1100 in maintenance (oil changes and new tires, plus battery)
Considering I bought it for $6,500 I've spent over $9,000 on it. I've put in over 8,000 miles in the last 4 months I've owned it. It has never left me stranded on major trips and it drives like new. Very happy with it and I plan to own it as long as possible.
202,460 Miles
Lexus replaced our dash for free recently due to the cracking, but I think it was also to replace the airbag (they didn't say that, but I don't see how you replace one without the other). You may want to check on it.
Johnny Rad (04-14-18)
. The only thing not working after driving it now for about a week is one of the rear window switches on the drivers door. The switch at the rear window works, so it's probably a bad front switch, no big deal. Will save that for a rainy day to fix.. After reading about the dash crack issues, I did a close inspection, and did find a few small cracks that are out ot normal sight. So is there a recall to replace the dash for free, or is it my expense. Has anyone replaced the dash as a DIY project?
Hope this helped.
What year is your GX?
2003 non-navi
MILAGE on your GX today?
176,352
i’ve owned it for 7 years
What repairs has it required?
- Both CV joints at ~150k
- o-ring inside transfer case @~150k mi (to stop transfer case oil leak)
- Cracking dashboard replaced by Lexus warranty enhancement in 2016 @152k miles (13 year old GX) =D
- positive battery terminal replaced ($24 fix).
- Bank1 Sensor1 oxygen sensor at ~ 160k mi
- Ignition key case broke at ~172k mi ($40 cut @ Lexus )
- Right and Left rear suspension air springs @ 174k mi ($182 ea) -easy DIY fix
What mods have you done to your GX if any?
Installed aftermarket Bluetooth
On a scale of 1-10 how much do you love it?
Would you buy another GX?
ABSOLUTELY
Post a pic if you have one
2003 non-navi
176,352
ABSOLUTELY
What year is your GX? 2008
MILAGE on your GX today? 84,500
What repairs has it required? Radiator, Front CV shaft axle
What mods have you done to your GX if any? Vizualogic Headrest DVD player, LED bulbs on headlights (low and high), fog lamps and steps, weathertech floor liners.
On a scale of 1-10 how much do you love it? It's definitely a 10.
Would you buy another GX? Yes, already did. Picked up a 2018.
Post a pic if you have one. Of course.
2008 Lexus GX470
Mileage: 118,000miles
Repairs: Radiator, Rear Brakes, Spark Plugs, Air Injection Pump, Front & Rear and Transfer Case Fluid Flush, (about to do) Timing Belt
Mods: RRW RR2-V Wheels 17"x8.5" / 285/70/17 Toyo Open Country A/T, (about to do) 2" lift, pod lights, projector retrofit
On a scale of 1-10 how much do you love it? 9.5/10 Probably keeping it forever.
Would you buy another GX? Definitely.
Toyota Prado
It comes from the Toyota Prado. I'm also interested in it and I saw it for sale here:
https://www.ebay.com/itm/Toyota-FJ10...19.m1438.l2649
Is it a self-install or is it something a mechanic has to do? does it affect any airbag warranty?
Thx for sharing
