GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Rear Cool switch not working?
Old 10-18-17, 11:48 AM
gus73
gus73's Avatar
Default Rear Cool switch not working?
Hi, in my 2009 GX470, the rear climate control works great, but only when the rear cool button is held down. Is this a toggle switch that is broken? Or is there a relay somewhere that has failed? I can replace the rear climate control switch assembly for around $50, but I want to be sure it is the switch that has failed. Thanks!
Old 10-18-17, 12:58 PM
chiph9
chiph9's Avatar
It's a toggle switch. Push on, it stays down. Push off, and it returns to the out position.
Could it be gunk trapped behind the button?
Chip H.
Old 10-18-17, 02:01 PM
gus73
gus73's Avatar
Okay, thanks. I will pull things apart and find out what's going on.
Old 10-20-17, 01:56 PM
gus73
gus73's Avatar
Default Simple fix to rear cool switch not working
This turned out to be very simple. The rear cool switch has thin plastic ribs between it and the adjacent buttons. One of these ribs had become damaged and bent somehow and was preventing the button from popping out enough to toggle properly. I pried and forced the rib back into place, and now the switch is back to toggling. Good as new.
musashi55
02-03-18 10:28 AM
HellBound
10-07-16 09:15 AM
filippos
NX - 1st Gen (2015-2021)
06-10-15 06:29 AM
Capirato
GX - 2nd Gen (2010-2023)
11-08-10 12:38 PM
Quick Reply: Rear Cool switch not working?
