Is it possible to program the air suspension?
You can "trick" the system by moving the rear height sensors to achieve a higher/lower "normal" position, your question is wildly vague though, not sure if this is what you're looking for.
Thanks Ian,
Thought I saw a post outlining a process to reset the system by following a progression like gearshift select neutral, set height control to high, wait 10 seconds, set to low, wait 10 seconds, set to normal......
buickman69
GX - 1st Gen (2004-2009)
03-16-15 09:20 PM
