GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Rear Brake Bleeding - GX470 won't start
Old 09-17-17, 03:30 PM
kdon
kdon's Avatar
Default Rear Brake Bleeding - GX470 won't start
Hi guys, was bleeding the rears on my wife's 07 GX470 using the factory service guide (key on, brake depressed to run pump, etc.). All went well, master cylinder reservoir never went below the mid indicator. Then I went to start the vehicle to go bed new rotors/pads, but the car now won't start... just a "tic - tic - tic" over and over.
Troubleshooting done so far:
- Pulled the negative terminal on the battery, hit the brake ~20 times, but same issue when trying to start.
- Service manual indicates there may be a DTC associated with using this method? Getting a friend's code scanner to evaluate.
Any help would be hugely appreciated. Thanks everyone.
Old 09-17-17, 04:48 PM
kdon
kdon's Avatar
Nevermind - diagnosed as low battery.
Old 09-18-17, 03:48 AM
burny
burny's Avatar
What happened
Old 09-18-17, 05:57 AM
chiph9
chiph9's Avatar
Yep. Battery.
I change mine every 3 years now, as I got tired of being stranded.
Chip H.
Old 10-10-17, 10:34 AM
artinist
artinist's Avatar
pretty sure you dont have to bleed them using that method unless you have replaced maser cylinder, etc. if there is no air introduced in the system, then push out the old stuff until you get new fluid
Jebelios
09-27-18 08:56 PM
dahiya
RX - 3rd Gen (2010-2015)
14
08-22-18 11:25 AM
EricChavez
02-07-18 10:59 AM
mandyfig
08-18-17 11:37 AM
Morgan91
05-08-16 08:26 AM
Quick Reply: Rear Brake Bleeding - GX470 won't start
