GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
No sound radio-Navigation sound OK, Service check: Audio H/U says "Chek" - GX470 2007
Old 03-15-17, 02:36 PM
uak
uak's Avatar
Unhappy No sound radio-Navigation sound OK, Service check: Audio H/U says "Chek" - GX470 2007
I have a GX470 (2005) and suddenly there is no audio from radio and CD. However navigation audio, all the controls, and LCD display (tracks, radio) works fine. I was researching and did the service test (turn tail light off and on three times while holding info) and Audio H/U says "Chek". Please find the attached.
Is this something related to fuse or cable, or perhaps bad amplifier? Going to the dealer is the last thing I want to do
Any help is appreciated.
Old 03-16-17, 09:26 PM
LoneHiker
LoneHiker's Avatar
The Audio Head Unit is the box with the cassette player and main audio controls. There are some threads about how to take apart the dash to remove the head unit. Check the cables behind it for binding/broken wires before assuming it has died.
The fact that DSP-AMP says OK tells you it's not an amp problem.
If the head unit is dead, I've seen replacements on ebay.
Old 03-17-17, 07:39 AM
maxx430
maxx430's Avatar
I had a similar problem where I had no audio but my navigation worked. It was the amp that caused the problem. I believe united radio it was that corrected my problem for about 475.
Old 03-17-17, 01:15 PM
chiph9
chiph9's Avatar
Agree. Try unplugging/replugging the "cassette" unit and see if that clears up the problem. Also look for pinched wires - there's a massive connector down by the driver's knee with lots of wires.
Chip H.
Old 03-18-18, 07:12 AM
cek347
cek347's Avatar
I know it's a slim chance on this old thread but if your still around did you get any resolution to the problem? I'm a new owner, 04 GX with ML. Doing a lot of searching right now with same problem. Going to try the diagnostic check now.
Old 03-18-18, 09:07 AM
cek347
cek347's Avatar
Just looked at his username. Hasn't been here last year. Just ran the test. HU: check Amplifier: Ncon. Ill go back to searching.
soerinder
07-22-20 03:48 PM
uak
03-15-17 02:46 PM
PeterSM
RX - 1st Gen (1999-2003)
10-11-13 06:21 AM
julius1980
26
05-19-09 10:39 AM
Quick Reply: No sound radio-Navigation sound OK, Service check: Audio H/U says "Chek" - GX470 2007
